Home > Technical (L322) > Yet another efing problem vibration through car :update |
trainmanone Member Since: 26 Jul 2012 Location: stockport Posts: 201 |
just to let you know not done anything on the car due to being ill but a lot better now so will be getting out and having a look over next few days have hawkeye diagnostics for l322 td6 in the manchester area ,pm for deatalis. |
8th Sep 2014 10:55am |
just had a thought there's a squeak from the rear as turning left or right, only started after the wheel alignment was done, cording to the printout rear wheels now perfect front camber and castor slightly out, could vibration be due to the rear bushes being kaput ???? have hawkeye diagnostics for l322 td6 in the manchester area ,pm for deatalis. |
24th Sep 2014 6:52pm |
Norway Member Since: 09 Dec 2012 Location: Høvik Posts: 123 |
Hows it going with this problem. Do you still get the vibration? -03V td6
2nd Nov 2014 6:34pm |
hi mate ,still got the vibration not had any time to have a look yet. off work in a few weeks so going to have a good look then . have hawkeye diagnostics for l322 td6 in the manchester area ,pm for deatalis. |
2nd Nov 2014 7:09pm |
Iw had the same vibrations for the last 2 years, sow i guess that if it was the TC it would have been in bits and peaces. Do com compression test of your injectors. If its not that, ist the joins some where. -03V td6
2nd Nov 2014 7:47pm |
right had hawkeye on the beast to clear eas issue and thougt id have a look for any more fault codes and found these
6th Nov 2014 12:09pm |
