Home > Technical (L322) > pressure static when filling |
Ah well, a fun three hours spent stripping down cleaning, drying (dessicant went from brown to white in the oven ) and putting back together of compressor. Nothing obvious on show, everything moved/worked as expected.
13th Sep 2014 12:46pm |
Weejock Member Since: 31 Dec 2011 Location: UK Posts: 416 |
The non-return valve may have been sticky (in the centre of your photo, rubber seal with the small spring that sits behind the metal disc). If it fails to shut on the return stroke of the piston (sucked shut) then the air won't move anywhere, it's just go up and down the bore and hence static pressure increase when filling. Likewise if the air intake is blocked. If the cylinder and/or piston ring is also worn the same will happen (air will go past the ring) but usually it's a gradual process of taking longer to raise over time before failing and not an intermittent issue like yours.
13th Sep 2014 3:30pm |
Thanks for the input weejock, and also for the offer of the spare cylinder head. There was a bit of muck on the "triangular" shaped rubber washer under the small spring, but wouldn't have thought it to be enough to cause a problem.
13th Sep 2014 4:47pm |
@ weejock
14th Sep 2014 1:00am |
Just run the Access to Off Road test: 2 minutes and 6 seconds.... .
14th Sep 2014 3:23pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7908 |
You seem to be going backwards Joe,
14th Sep 2014 3:46pm |
All I am doing is trying everything I can think of to solve this problem before shelling out on a new compressor. A learning process (labour of love type thing) and hopefully useful for others should they experience the same problem.
14th Sep 2014 4:56pm |
You can't bypass the pressure sensor. You can check the voltage on the yellow wire at the sensor, it probably should be 5V (standard sensor reference voltage). Likewise the white wire should be ground. The other wire will be anywhere between 0V and 5V and be proportional to the air pressure. You could measure at the sensor and ECU and see if they tally.
15th Sep 2014 7:08am |
Reed valve is in the top of the piston....
15th Sep 2014 11:17am |
RCusden Member Since: 12 May 2012 Location: NarberthPembrokeshire Posts: 186 |
Inspired by this thread I have dug out the old compressor that I rebuilt using one of meerbush's kits, I found the reason it didn't work after I rebuild it was there was a split in the pipe that connects the compressor to the car. When I rebuilt it I put it in the car to try it and couldn't hear the leak. The error message came right back so being a grumpy I ordered a new one from paddocks which is now in the car. Running it on the bench I could hear the hissing. I'm sure joe has probably checked this by now but I thought I would post my findings. And to say I now have a working compressor for sale
15th Sep 2014 12:18pm |
Useful info Roger Not checked for leaks, but given my fault is intermittent (can go for a couple of days without fault, seems unlikely - though I won't rule it out
15th Sep 2014 5:46pm |
Managed to get a different fault out of the car today, after trying out a bit of up and down. This time it was the:
10th Oct 2014 12:31pm |
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1898 |
At least you now know what was giving the main problem , just a shame it was not the cheaper option like the pressure switch. If it dont work.......burn it!
10th Oct 2014 4:16pm |
I wondered where this thread was going for a minute.... It does look like it's the pump then, hope the new one fixes it alright, can you post an "up and down time" when you put the new one on... it'll give me an idea how far away mine is from demise... Cheers Pete __________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Parchment over Navy Interior. Sold 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand, Jet Interior. Sold 2002 L322 Vogue 4.4 V8 Epson Green, Ivory over Aspen Interior (Fatty Offroader) Sold -Click for Project Fatty off roader- |
10th Oct 2014 6:07pm |
