![]() | Home > Maintenance & Modifications > Door Panels |
| Ian Donkin Member Since: 17 Aug 2010 Location: A Yorkshireman in Surrey Posts: 15
Probably a late answer for you now, but I did the drivers door in mine today for exactly the same reason...
| andyw Member Since: 15 Oct 2009 Location: united kingdom Posts: 161
Paul ive had that problem i got round it by doing the following
| kb5 Member Since: 20 Jan 2010 Location: currently in The Sudan, dont ask Posts: 63
| Paul Grainger Member Since: 13 Jun 2010 Location: Mansfield Posts: 23
Thanks for your replies, I did entually get the gap right, I removed the lower window trim, and used a bit of brute force! Scarey at the time, but the end result was worth it!
| sidmini Member Since: 20 Sep 2010 Location: kent Posts: 41
Guys need your help. I want to replace the peeling window switch trim passenger side (uk) but before I start the removal do I need to disconnect the battery to stop air bags going off or air bag light ? any advice? Also is there an order to remove the plugs from inside the door card? |
| dan_uk_1984 Member Since: 12 Nov 2008 Location: Bude, Cornwall Posts: 3758
thanks for the info Dan should help! |
