![]() | Home > Maintenance & Mods (L322) > Sidestep Bracket Corrosion..... |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 8000 ![]() ![]() ![]() |
So, it would appear that my far too ample frame has finished off the drivers side sidestep.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35874 ![]() ![]() |
i have a feeling that these are not OE type steps Mark as the bracket should be in one piece with the step,
Ah. Thanks Stan.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8822 ![]() ![]() ![]() |
I've still got the pair that came off mine, they are originals, they are a bit rusty but only surface, still good and strong, took my not inconsiderable weight....
That's very kind of you Pete.
I see you have added a pic whilst I was typing......
PM sent Pete
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6432 ![]() ![]() |
Mine (earliest of early cars!) are the same as stan's photos and Haylands too. .
Well as they are no use, I sort of investigated removing the ones that are on, only to find I can't undo the bolt going into the chassis. The edges of it seem a bit corroded. Not sure how tight it is, as I can't get purchase with a socket or spanner.
I sheared the bolts off on one side (the inner ones). Was able to drill out the remaining stud, then drop a new bolt through the hole from inside the chassis boxing - LR provide suitable access holes. .
Mark,
