Home > Technical (L322) > Need some help with the Navigation systems please
mzplcg
Not the usual request I know but here goes.
Car is a 2007 which did not have factory NAV. God knows why as it has loads of other goodies but there we go. Anyway, when I collected it it had aftermarket NAV connected to the onboard touch screen.
It does have the full touch screen and the bluetooth module with all the other bits I would expect on a Vogue except the Venture Cam.
So, the aftermarket NAV was rubbish. Actually, it was worse than that so I removed it. Now I want to replace it with the genuine article. LR have quoted me almost £2k for the parts kit and a further £500 to fit it. Not being tight or anything but to pay £1300 for just the DVD drive is a tad ridiculous.
So, what I need are the part numbers for the various kit parts please. E.G Loom number etc. I can get a DVD drive form the bay if needs be or even someone like a 4X4 breaker. I did ask a breaker if I could remove the parts myself from a crash damaged one but good old "Elf-'n'-Safety" won't let them permit this. But, having rooted around, it seems the wiring and plugs required are not present so there seems to be an over-loom which is needed as well.
I'm not too fussed for the TMC module as these are not required to make it work in basic mode but again, if you have the part numbers this would be great.
Beer tokens exchanged for info Wink
Alternatively, if anyone fancies letting me look round a 2006 onward Vogue I would also be happy to exchange beer tokens for that as well.
Cheers
Dom
Post #24871 6th Aug 2010 4:20pm
sounds like you got a big job there dom, good luck..
Post #24876 6th Aug 2010 4:39pm
this any good somebody selling it on the forum ......
http://www.fullfatrr.com/forum/topic2639.html
Post #24890 6th Aug 2010 5:33pm
i think willeephille has sold this now mick....
Post #24907 6th Aug 2010 6:32pm
nbunney
United Kingdom 2018 Range Rover Autobiography SDV8 Corris Grey
I think he may need the Jag unit, that's y is so much
Post #24910 6th Aug 2010 6:37pm
afaik, the non-touch uses coax and the touch screen uses optical cabling..
Post #24912 6th Aug 2010 6:40pm
nbunney
'when I collected it it had aftermarket NAV connected to the onboard touch screen. '
Post #24916 6th Aug 2010 6:52pm
mzplcg
Yep, with a gizmo interface box. Utter junk and accurate to about half a bleedin' mile. Useless.
Post #24931 6th Aug 2010 7:50pm
