![]() | Home > General > 2008 range rover tdv8 brembo discs and pads replacement cost |
| Tim in Scotland Member Since: 25 Mar 2007 Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland Posts: 2103
Try GEMM at Larbert - they are non franchise Land Rover specialists.
| specman Member Since: 20 May 2010 Location: Fife Posts: 196
To add to Tim's excellent list of info there is also Mike Aitken 4x4 near Ladybank in Fife 01337 831114
| JMC Member Since: 01 Feb 2009 Location: Aberdeen-Angus Posts: 263
Before you go any further, what makes you think that you actually NEED to replace these items? Is it just because some stealer has quoted you for a job that you assume it is really needing done?
John, I agree with you on the "is it necessary front"! Over on RRS there are plenty of stories of guys with dealerships wanting to replace Brembo brake components unnecessarily - maybe mbdj should go for a second opinion. In three years of TDv8 RRS ownership I never needed any replacement Brembo components except a replacement rear disc which was done under warranty. Now the FFRR has morphed into a 2012MY RREvoque Dynamic Lux Plus Auto SD4 Coupe in Fuji White with full ebony interior |
I've done the pads on my 2009 TDV8 at 18k miles myself. Disks were perfectly fine but I suspect 'some' stealers would have automatically changed the discs, and charged a premium at the same time. |
| mbdj Member Since: 14 Jul 2010 Location: scotland Posts: 20
thanks everyone for your quick reply's the discs have groves top and bottom but they work fine so i thought i would ask the local dealer for a price to change discs and pads front and rear going to phone around some of the names mentioned to see if it can be done cheaper thanks again. |
| Mikey Member Since: 10 Jan 2008 Location: Scotland Posts: 31
| ukrangie Member Since: 20 Jun 2009 Location: London Posts: 486
I just had my discs and pads replaced by Lookers at Bishops Stortford for £775 after an independent told me they needed to be replaced. The independent wanted £40 more for the same job. Thankfully I got through a 1800 mile drive around France before the brakes started to crunch. Paul
| mzplcg Member Since: 26 May 2010 Location: Warwickshire. England. The Commonwealth. (NOT the EU) Posts: 873
Like JMC says, if they need done then do them yourself. Basic tools and a trolley jack are all that's required.
| All times are GMT |
