Home > Maintenance & Mods (L322) > End of my tether |
I suggest to do fuel filter if it hasn't been done recently, although unlikely that that is the cause.
2nd Oct 2014 11:24am |
Faulty fuel pump relay? |
2nd Oct 2014 11:41am |
Skorpion84 Member Since: 02 Oct 2014 Location: Manchester Posts: 16 |
First of all thank you both for the response.. Fuel filter has already been changed around the same time the inline pump was. Ill mention here that on a good few occasions over the 3yrs owning it I have ran it mega low so indeed the grime in the line or stuck in the tank as you suggest both make sense, this has not been looked into yet.. Its covered 110000miles & I have here a cam sensor bought today which is ready to be fitted in continuation of my wild fault finding...
2nd Oct 2014 7:56pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34925 |
are there not 2 fuel pumps? ... - .- -.
2nd Oct 2014 8:04pm |
Yeh stan inline fuel pump & primary pump situated in the tank by the sound of it... Current:
2nd Oct 2014 8:08pm |
sako243 Member Since: 26 Dec 2013 Location: Wales Posts: 605 |
I had the same issue with a 3.6TDV8 and was the lift pump in the tank. |
2nd Oct 2014 8:10pm |
Chauch Member Since: 09 Feb 2014 Location: Beds Posts: 303 |
I had a very similar thing on an old Mustang many years ago, and that was cr4p in the bottom of the fuel tank that kept clogging up the filter, always at the same sort of miles driven, then of course drained away by the time you checked it so all appeared normal and fuel appeared to be pumping OK. 4.2 Supercharged Vogue SE |
2nd Oct 2014 8:16pm |
Sako is this otherwise known also as the sender unit as this has been mentioned by a friend who works for stratstones... Current:
Sometimes the £20 a day just winds me up on top of other daily expenditures & yes I have made her feel the thirst, & this is how she gets me back.. So it comes about there is gunk apparently what sits on the bottom of the tank & this getting sucked up sounds like the 1.... Is there a way I can flush this myself or is this a messy business? Current:
2nd Oct 2014 8:28pm |
The good thing is that the plastic fuel tanks don't have the rust problem that metal tanks used to have, so that is a big plus. But water/crap getting into the tank over time is a potential problem since the car has been around for a while.
3rd Oct 2014 2:52am |
With all that you have mentioned, it is destined now on a flatbed to a renowned indy up lancashire.. The grime sucked up into the system is making a lot of sense right now knowing my car the way I do. Atleast its got all its potentially failing sensors & components replaced in the process.
3rd Oct 2014 10:29am |
trainmanone Member Since: 26 Jul 2012 Location: stockport Posts: 201 |
Did you get this sorted
18th Dec 2014 8:39pm |
stcstc31 Member Since: 01 Jul 2014 Location: dublin Posts: 209 |
mine did just this
18th Dec 2014 8:59pm |
Feel rather p'd off but at the same time feel good knowing any & every fuel related component, connection is replaced or otherwise greased up & revitalised where it deemed fit..
23rd Jan 2015 1:41pm |
