Home > Technical (L322) > P010c - 21 (2c) fault code
DavidC
United Kingdom 2007 Range Rover Vogue TDV8 Stornoway Grey
Hi, need help diagnosing fault polease,
exiting roundabout a few minutes ago, lost power, engine revved ok, but no real power.
display showed "Engine System Fault" after a few minutes, thankfully home was only 500 m away.
IDtool shows code P010c -21 (2c).
Nothing revealed in a search of this forum, but the code could relate to MAF according to google.
Any ideas of what I need to do?
Thanks in advance...
Post #284098 2nd Oct 2014 5:34pm
paulmoran2
England 2013 Range Rover Vogue SDV8 Mariana Black
Split turbo hose??
http://www.fullfatrr.com/forum/topic26843....turbo+hose GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
HAVE 1999 Discovery 2 GS 4.0 V8 - Silver - Off Road Toy
GONE 2013 L405 4.4 SDV8 Vogue. Black with Silver roofline and 22" s
HAVE 2015 Jaguar XF.
Post #284102 2nd Oct 2014 5:50pm
DavidC
thanks, but have both off and no sign of a split anywhere. I have squeezed them to make sure there isn't a hidden one.
Any other ideas?
I appreciate the help
Thanks
Post #284110 2nd Oct 2014 6:37pm
Check the bottom turbo hoses as well as the short ones near the turbos.
Don't often go but might have popped. There is nothing that can't be fixed with a hammer😜😜
Post #284112 2nd Oct 2014 6:53pm
DavidC
Thanks - nothing I can see is obviously wrong.
Have just driven it again to see if anything I had done had cleared it, but still same, plus I notice an unusual noise near side engine. Odd intermittent whirring - very hard to describe.
I will call recovery in the morning and get it take to the dealers.
Post #284119 2nd Oct 2014 7:13pm
DavidC
Update: Problem was seized passenger side turbo.
Unfortunately this was within the 90 days W&T exclusion of Warranty Direct and they maintain it is wear and tear - within the 90 days by 3 days..... 90 days is 90 days unfortunately. (makes the warranty not a 12 month warranty in reality as everything will likely be w&t). Previous warranty was by Warranty Wise and they possibly would have paid out...
I had followed all the advice here, frequent oil and filter changes, drain oil via drain plugs not by vacuum lift.
In addition, I always idled for 30 secs before switch off, regularly use Redex or Forte diesel treatment, had both EGRs replaced at first sign of error. (The EGRs would not have been covered by Warranty Direct as they do not cover failures due to carbon build up)
I believe (as does the mechanic) I could not have done more maintenance to prevent the failure. Unlike other turbo failures I read about, this happened at 9 miles into a journey, 3,200 miles after the EGR replacement. Thankfully the engine did not suffer damage.
Now I have the pleasure of waiting for the drivers side turbo to fail - only a matter of time.....
Wonder if Warranty Direct will pay for that one??
Post #287683 20th Oct 2014 10:57am
Sorry to hear that. What's the damage?
Post #287686 20th Oct 2014 11:10am
DavidC
Thanks - cost was just under 2.5k, apparently other side is less labour, but higher part cost - so will be about the same.
Post #287687 20th Oct 2014 11:15am
Mikey
Just replaced both turbos on a customers car.
The old turbos were sent away to be inspected at the request of the warranty company. They had both "failed" due to lack of oil.
Upon checking the old oil feed pipe, there was definately a blockage in the pipe. I still have the old pipe, to cut open and inspect when I have a spare half hour.
Upon that basis, I wonder if it it would be worth replacing the oil feed pipe every 2-3 years as a serviceable item?
Post #287714 20th Oct 2014 1:33pm
ebajema
Sorry to hear that you had such bad luck. I think Mikey may be on to something, better get the oil pipes check to see if they are clean and clear.
I almost bought a TDV8 until I found out one of the turbos failed and it was being replaced. That is when I remembered that sometimes there are turbo issues with forum cars. For me it was the main reason to then go for the SC.
Anyway, I hope that you won't have any more issues whatsoever Smile MY 2010 5.0 SC Galway green and sand interior!!
Post #287728 20th Oct 2014 3:20pm
SKOT
England 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
Ouch! Shocked Sorry to hear, David.
At least the engine is OK, keep telling yourself that it could have been worse! Confused 2006 4.2 SC
2019 Renault Zoe Dynamique Nav
Post #287752 20th Oct 2014 7:22pm
DavidC
Thanks for the kind words.
I spoke with the mechanic, he said there was a plentiful supply of oil.
One other thing that confuses me - if the turbo was wearing out before the failure, that would suggest performance would be reduced and once a new turbo is fitted I would expect to experience better economy and a livelier motor - this is not the case... it feels the same and if anything, slightly worse economy.
Have considered changing to something else - but nothing appeals to me, 5.0 SC is an option, but still too expensive for me.
Post #287888 21st Oct 2014 11:23am
