Home > Technical (L322) > Td6 Still Won;t start |
Fuel pump near the rear wheel would be the first item to check |
11th Oct 2014 7:58am |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7635 |
Thats what I'd have thought initially, but he says pumps have been replaced, so I assume it was both of them.
11th Oct 2014 9:48am |
Fuel pump relay? |
11th Oct 2014 9:54am |
The rail sensor could indeed be at fault.
11th Oct 2014 10:15am |
theanswers Member Since: 30 Jul 2012 Location: Ireland Posts: 302 |
Hey guys thanks for the reply. The fuel pump relay is ok, because there is plenty of fuel at the filter and the injectors.
11th Oct 2014 11:48am |
I've seen on here somewhere the need to replace the fuel rail wiring loom (complete) or the fuel regulator as this can cause similar problems?
11th Oct 2014 12:39pm |
But if easy start gets her going and she works fine after that, I would check the glow plugs and wiring first. Or have you tried and tested all that already ?? MY 2010 5.0 SC Galway green and sand interior!!
11th Oct 2014 12:43pm |
Will have a read of that link now...
11th Oct 2014 1:15pm |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1692 |
You need to do an injector leak back test, while still on the car. This will highlight any internal leaks in the injector, which is a well known issue with the TD4/TD6 |
11th Oct 2014 1:20pm |
Very true you don't need the glow plugs unless it gets to -10 or lower they then help with cold starting quite a bit!
11th Oct 2014 3:28pm |
Cheers Lads. I might give that a try.
11th Oct 2014 6:07pm |
I'll have a look in a bit and compare for you FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
11th Oct 2014 6:17pm |
Cheers Kingpleb. When I say turning over; I mean attempt to start.
11th Oct 2014 6:25pm |
When I had issues I was getting a low pressure reading of 389.3 low pressure and 16376 high pressure.
11th Oct 2014 6:28pm |
