Home > Maintenance & Mods (L322) > Acceleration died - Throttle actuator shutdown
pld118
A short journey tonight, the front brake squeal started so I pumped the brakes a few times and went to accelerate and... Nowt there followed by a dash warning.
Thankfully, having taken heed of Cam Tech Craig's lead, my newly acquired IID tool actually lives in the glovebox of the car and so I was able to plugit in to have the following fault read:
"Throttle actuator control system forced engine shutdown [Fault Code P1205-00 (2Cool"
I then used then IID tool to clear that fault code and hey presto, normal service was resumed. Thank goodness for the IID tool because until using it, the car was going nowhere!
What's going on!!!
Post #285898 11th Oct 2014 8:51pm
Ryan its Probably a "feature"....... Whistle
Don't know but sounds like a error between the accelerator and the throttle control in the engine. Possibly one to ignore until it happens again Rolling Eyes There is nothing that can't be fixed with a hammer😜😜
Post #285918 11th Oct 2014 9:53pm
Mikey
Did you catch the brake pedal at the same time as the throttle pedal?
If not, then as above. See if the fault re-occurs
Post #285919 11th Oct 2014 9:58pm
According to the bible that is rave, the throttle position is recalibrate each each ignition cycle.
The code reads as p210500 - throttle MIL request due to fuel cut, action is to check for dtc indicating reason for fuel cut and follow action indicated for those dtc's. Rave p949.
As you had no other dtc codes then probably related to stamping on the brakes......... There is nothing that can't be fixed with a hammer😜😜
Post #285920 11th Oct 2014 10:13pm
pld118
Thanks chaps, particularly NMJ... I did indeed stamp on the brakes.
Without the IID tool though...
Post #285922 11th Oct 2014 10:31pm
Wonder if it thought it was about to be in a crash and cut the fuel...... Possibly a system somewhere for that? There is nothing that can't be fixed with a hammer😜😜
Post #285960 12th Oct 2014 8:13am
pld118
This happened again last night. Same as before, when I was braking, accelerating and braking in quick succession to try and stop the onset of front driver's side wheel squeal. Disconcerting when it happens but it does seem like a vehicle defence mechanism of sorts. Cleared the fault in seconds with the IID tool.
Post #287817 21st Oct 2014 5:26am
You maybe giving her travel/motion sickness to which she objects and requests a break sir Whistle Rolling Eyes Thumbs Up
Post #287874 21st Oct 2014 9:40am
Seems like the an ELBSAP type error....... Drive on.
(Error Located Between Seat And Pedals) Rolling Eyes Very Happy There is nothing that can't be fixed with a hammer😜😜
Post #287990 21st Oct 2014 5:43pm
pld118
Don't get me wrong, I didn't fear much wrong with the car to make it shut down other than the give her a break conclusion... Or new pair of brakes [pads] Laughing
Just good to have the IID tool to restore normal service Thumbs Up
Post #287992 21st Oct 2014 5:47pm
PatGAPInnov
Site Sponsor
Canada 2010 Range Rover Autobiography 5.0 SC V8 Causeway Grey
This is why we've gotten into this field in the first place, I wouldn't leave without one myself! Thumbs Up
Post #288123 22nd Oct 2014 4:26pm
pld118
Couldn't agree more Pat. Can't believe I didn't get an IID tool sooner. Also a worthy reminder to carry it in the car which unless having read Cam Tech Craig's previous post about doing just that, I would have stored mine in my garage.
An essential bit of kit and for the record, my non BT IID is perfectly adequate for my needs and I don't long for a BT version, just like I don't long for a 5.0SC! Laughing
Post #288125 22nd Oct 2014 4:34pm
PatGAPInnov
Site Sponsor
Spot on, the regular IIDTool still has its place even with the BT offering. It does feel at home in your glovebox, maybe I should add a note in the user manual!
Had the chance to drive a few different configurations and no matter which engine, the Range Rover is an astounding vehicle.
Post #288128 22nd Oct 2014 4:47pm
Mikey
My IID never leaves the door pocket, unless it's being used Thumbs Up
Post #288137 22nd Oct 2014 5:41pm
