![]() | Home > Technical > Un even Suspension Fault |
| andyw Member Since: 15 Oct 2009 Location: united kingdom Posts: 161
i used Guava top bunch sounds like a pipe cleaning requirement, are both corners teh same hieght on the lo side if so dont sound like a air bag however could be hieght sensor |
| bjs Member Since: 27 May 2010 Location: Surrey Posts: 35
Hi Andy
| Tim in Scotland Member Since: 25 Mar 2007 Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland Posts: 2103
To see if it is a failed height sensor switch the screen to 4x4 mode - any dead sensor should show as a red bar above the wheel where the malfunctioning sensor is Now the FFRR has morphed into a 2012MY RREvoque Dynamic Lux Plus Auto SD4 Coupe in Fuji White with full ebony interior |
Sorry don't follow...
| scarey Member Since: 13 Jul 2010 Location: stan in swindon Posts: 7052
I'm using Safari on an iPad so cannot click on the car icon in your signature bj. Maybe older versions of the satnav system don't have the off road info page like the RRS/D3-4/Freelander2 and newer Ffrrs then Now the FFRR has morphed into a 2012MY RREvoque Dynamic Lux Plus Auto SD4 Coupe in Fuji White with full ebony interior |
Update
| All times are GMT |
