![]() | Home > Maintenance & Mods (L322) > Blown head gasket! Only had car 3 weeks! Hellpppp!!! |
Ziggy Member Since: 26 Dec 2011 Location: West midlands UK /sydney AU Posts: 265 ![]() ![]() |
G'Day Digger
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7991 ![]() ![]() ![]() |
That's what I was thinking. Unless there is further damage.....
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
I have same engine, it is actually a modified bmw 7 series engine. known as the m62tub44 sometimes called m62tu44. the difference is the sump and oil pump in the sump. it is different from the earlier easy to find m62 engine as that doesn't have the VANOS ie its not bulging at front of rocker covers, its straighter instead. so heads on later bmw engine, are same as your car (m62tub44). you can remove a head and have it checked for cracks, warps and find a secondhand one. but you should buy it complete with its camshafts.(I'm told) if you have a diagnosis of which side you are lucky. sounds like you may have run it low on water, and overheated it. what you could have done is run the pistons hot against the bore lining. if those are scored it terminal. the other similar engine, (same engine as RR) is the bmw X5 4.4 not 4.6
Laurie915 Member Since: 11 Sep 2011 Location: Canberra Posts: 72 ![]() ![]() ![]() |
Are you sure it's a head gasket ?
Bagus Member Since: 15 Apr 2014 Location: London Posts: 202 ![]() ![]() ![]() |
Did you get this sorted?
jdooley81 Member Since: 15 Oct 2014 Location: London Posts: 5 ![]() ![]() ![]() |
Hi all, thanks for the amazing responses. for my first service I brought the motor to LRR and asked them to let me know if any issues. They really are nice guys there. They found when performing the service that a gasket fix liquid had been used so Duely informed me and at my request carried on with the service and fitting a new alternator as the old one failed in the first week of having it (charged battery over night before going for service).
well, while its true that you are loosing coolant, have you had it proved to be the head gasket, (in a reasonably cheap) fashion?
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2286 ![]() ![]() ![]() |
One of these will help
Thanks for the reply gents. I've taken your earlier advice and researched bwm Indy near me. I'm going to call them in the morning and query if they are comfortable sniff and compression testing to see if it truly is a head gasket issue. I've also sent a query to Ivor Serle about a re manufactured or 2nd hand engine. Thought best to get the feelers out and see what sort of price I'm going to be quoted.
To be honest the gasket fix sealant would have been used as a general coolant sealant i.e. if you tip enough in t seals all sorts of leaks temporarily doesn't mean it was a head gasket often it is rad related good luck |
the 'change the engine' theory is a hammer/nut method, and lets face it, the engine 'seller' is not going to guarantee the car unless he fits it. but he's not a bmw/LR 'trained' mechanic. and the trained mechanic, does not want to guarantee the car, as he knows nothing about the 'new' engine. hence its your problem, when it doesn't solve the problem. but everyone gets paid! please consider this before throwing your wallet onto the bonfire.
Hi All,
how are you getting on? I tried to call you to chat about your dilemma but got answerphone. |
Hi All,
