Home > Maintenance & Mods (L322) > Noisy Like Pram Suspension Arm & Steering |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8479 |
Think it might be the cold Ryan,
5th Nov 2014 10:37pm |
pld118 Member Since: 25 Mar 2013 Location: Bairns Posts: 4218 |
Just read your own steering post Mark and whilst not initially thinking that yours would be cold related, touch wood, hopefully you're right on both counts.
6th Nov 2014 12:17am |
Going to have to get under it and have a look, can almost feel the clunk up the testing wheel, doesn't do it on the straight ahead, just when over 3/4 lock....... There is nothing that can't be fixed with a hammer😜😜
6th Nov 2014 12:39am |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16187 |
Your squeak will almost certainly be a dry balljoint sir... Happens a lot You have three per front corner (steering, lower front & lower rear)
6th Nov 2014 11:24am |
Top tip Craig, thanks.
6th Nov 2014 11:26am |
Edited sir |
6th Nov 2014 11:27am |
6th Nov 2014 11:28am |
CG-SC Member Since: 06 May 2011 Location: Falkirk Posts: 528 |
I had this happen on mine on the LHS, like your's it was SO LOUD.
6th Nov 2014 4:36pm |
What do you mean, before I ask CG...
7th Nov 2014 12:26am |
PaulTyrer Member Since: 22 Jul 2013 Location: Devizes, Wiltshire Posts: 1227 |
You forgot, D All of the above. Personally I would have gone for 'C' as I suspect the hidden 'EBA' (empty bank account) chip has activated! Ours does that on a regular basis... But I still love it! |
7th Nov 2014 12:38am |
