Home > Maintenance & Mods (L322) > Common rattles or vibrations on ffrr's |
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 |
Hi mustard. Had exactly the same as you since owning the car. Only happens at really slow or stop speed. I think I've narrowed it down to the steering or brake driver's side. It may just be a quirk with these cars cus others on here have had same and not found an answer to this problem.
17th Nov 2014 7:32am |
Forgot to add , also got vibration off front brake mud shields drivers side particularly bad but wont change until I change the discs next year. This does happen at about 1,000 rpm and can do it while not moving. Mud shields fix or replace are well documented on here. |
17th Nov 2014 8:25am |
Scottyav Member Since: 11 Feb 2013 Location: Cannock Staffordshire Posts: 1194 |
I've a vibration at 55 ish again when in top had box done a few months ago and all bushes and rods are good as are the tyres as virtually new all round it's driving me mad now and have no idea, maybe the TC is slightly out of balance as 1mm weight out can cause apparently going to see Neil smith this week _____________________________________________________
17th Nov 2014 8:37am |
Sorry to hear that mate
17th Nov 2014 9:01am |
Mustard Member Since: 25 Jun 2013 Location: North of South Posts: 299 |
I cant feel any vibration inside the cab, only hear it clattering away underneath me |
18th Nov 2014 12:10am |
SMUTT Member Since: 30 Jun 2014 Location: Cheshire Posts: 459 |
I get exactly the same. I too am quite particular about these things being perfect.
18th Nov 2014 1:09am |
Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804 |
More than likely to be the front or rear brake disc dust/mud shields. They are held on by three screws and have a habit of rusting away and becoming loose, leading to the sometimes tinny rattle or clatter you describe. If you look behind the front or rear brake disc, you will see the shield, give it a shake and that will tell you if it's solidly fixed or not. If the shields are loose, you can sometimes get away with resecuring them using oversize washers to cover the rusted screw holes on the shields. Otherwise, you can cut them off and discard them or replace them. Due to the way the shields are made (pressed piece of sheet metal) the official LR way to replace them is to take the hub off to get the new shields on, however an easy fix is to cut the new shield from outside edge to centre hole, bend the flap of metal out of the way (the shields are quite flimsy construction), slide into position and secure with new screws, then bend the metal flap back into position and tack weld where the cut was made. Let us know if you find what it is. |
18th Nov 2014 2:22pm |
Excellent, we will be looking at them tomorrow so shall let you know if it was them (I hope it is) |
19th Nov 2014 10:44pm |
bertie wooster Member Since: 16 Nov 2014 Location: Sutton Coldfield Posts: 29 |
I have recently experienced a rattle on a L405.
20th Nov 2014 8:26pm |
