Home > Maintenance & Mods (L322) > L322 air con pressure help |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6653 |
Are you sure it just doesn't need re-gassed? Got - 2017 SDV8 Autobiography in Loire Blue
20th Nov 2014 10:33pm |
SMUTT Member Since: 30 Jun 2014 Location: Cheshire Posts: 459 |
Is the passenger side vents colder than the driver side.
20th Nov 2014 10:38pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34912 |
could be the condenser leaking, its right at the front and liable to get hit by stones and road debris... ... - .- -.
20th Nov 2014 10:45pm |
Mistercorn Member Since: 01 Feb 2014 Location: Nottingham Posts: 109 |
I had it regassed, it appears to have pressure, it just doesn't change much when turned on. That said I am not sure what the pressure should be. Hence my request for somebody with a working one to check.
20th Nov 2014 10:51pm |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2024 |
its a no-brainer to get it regassed, because, (at least they used to) they guarantee that if it doesn't get colder by about 4 degress. its free. also, if you need a condenser, because of no gas pressure, and leak etc. they are about £90 on ebay. if you need the pump, they are on ebay for about £225 new both not the hardest things to change, but I did mine and removed water rad at same time. the gas also has a lube in it.
20th Nov 2014 10:57pm |
It did have a leaky condenser, which was changed. I then had it regassed. It held the vacuum but they had trouble regassing it and afterwards it wasn't getting colder so I wasn't charged. I have got a spare compressor but want to check the pressures with known good ones before paying to have it changed. I can't think what else it can be.
20th Nov 2014 11:02pm |
Katash Member Since: 10 Apr 2011 Location: Hereford Posts: 700 |
I did a post 18 months ago and posted my pressure values. |
21st Nov 2014 12:08am |
I have found it, it looks like you were seeing about 15-16 when turned on, but still no values for when it was off. Thanks very much though, half way there.
21st Nov 2014 8:23am |
is your pump clutch engaging? you might see it spin up when turned on. with a torch placed. -mind your hands on the belt though. |
21st Nov 2014 10:49am |
Yes it is engaging, the pressure does change slightly and it can be seen to be engaging.
21st Nov 2014 10:51am |
alfapat Member Since: 09 Apr 2017 Location: Elgin Posts: 349 |
Looking for answers off this post, my system was gassed perfectly last summer and has worked well up until now. My Gap tool reads 6.5 , I presume that’s psi, so maybe low, that’s why I on this thread to see exactly what pressure should be there. I cannot find the the link by Katash to see the pressures posted by himself , that’s why I am on here. Halfords will not let me have a refill can as my compressor is not turning , so my call to them is that by charging the system with the can this will start the compressor , their gauge shows low .... but ? I have a manifold system to monitor gassing in and in the past I have used these cans to restart the compressors, so I am a bit stuck unless I do some ground work. So pressures please! |
9th May 2018 12:48pm |
knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 701 |
if I remember correctly, I put 35lb in mine with the engine doing about 1100 RPM RR 2005 4.4 petrol
9th May 2018 2:16pm |
So about 7kg not much needed but how much to start with and was the compressor going before you did it? |
9th May 2018 9:56pm |
Sorry I didn’t make that very clear.
10th May 2018 2:48am |
