![]() | Home > Technical (L322) > air suspension filter |
darrenmax Member Since: 20 Apr 2010 Location: antwerp Posts: 420 ![]() ![]() ![]() |
i was reading the autocar buying guide and they mentioned that most garages overlook the air suspension filter when servicing, where is this located on the vehicle and does anyone have a part number for it ? 2002 td6 vogue, 06 supercharged facelift
They may mean the "Dryer" it's filled with desiccant which absorbs all the water. It's not a filter as such, but should be replaced if you live in a very damp climate, as the EAS drawers air from inside the car you should always leave the A/C on.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35770 ![]() ![]() |
where abouts is it dan and how can we check its ok... ... - .- -.
Seems to all be in the compressor box housing: "Attached to the compressor is the air dryer which contains a silicate box for removing moisture from the compressed air. Air supplied to inflate the air springs passes through the air dryer. When the air springs are deflated, the exhaust air also passes through the air dryer, removing the moisture from the unit. Attached to end of the air dryer unit is a solenoid operated exhaust pilot valve. This valve is opened when the air springs are to be deflated." ![]() |
Air dryer unit:
just caught up with this post , thanks dan... |
where is it hidden in the car ? 2002 td6 vogue, 06 supercharged facelift
RRVSE Member Since: 18 Apr 2009 Location: Bury Posts: 597 ![]() ![]() ![]() |
The air suspension compressor box is underneath the spare wheel ,it's underneath the large black metal cover (which the spare wheel bolt/retainer screws into from memory). The box also has a seal between it and the floorpan. The common issue with the EAS failing is a bog-standard valve (similar to those used on air tools) getting blocked (covered somewhere on the forum). I'll let the more techie RR boys correct me if I'm wrong though. |
when i opened the compressor up last week that air dryer in your link was definately not inside the compressor housing 2002 td6 vogue, 06 supercharged facelift
