Home > Maintenance & Mods (L322) > Fuel leak
Scottyav
United Kingdom 2007 Range Rover Autobiography TDV8 Zambezi Silver
Fuel leak
Had a smell of fuel the last week which I thought was coming from by the fuel tank, had a look for the first time today and it's the rear canister split on the o/s rear chassis rail is this the secondary pump and anyone know the part number for 2003 TD6 thanks Thumbs Up _____________________________________________________
Zambezi silver Vogue Se unique Smile
Post #298393 11th Dec 2014 4:37pm
The fuel pump is on the near side in front of the rear wheel underneath a bolt on flap
Post #298394 11th Dec 2014 4:42pm
Scottyav
Apparently it's part of the FBH setup, was totally corroded and shot but had the number 89372A on it which is webasto 12v dosing pump, pulled the pipes off either end and joined it together with nylon pipe taped the electric plug up and runs fine no bongs on dash or fault codes no FBH smell anymore or motor noise 👍👍 not as if it's siberia so will get round to do it maybe one day but the cabin gets hot inside really fast anyway so not bothered or concerned tbh Thumbs Up _____________________________________________________
Post #298667 12th Dec 2014 7:12pm
I really do not understand why they put it there, should be in that protected cubby with the secondary pump. Actually, might do a mod to put it in there Smile .
Post #298669 12th Dec 2014 7:25pm
birchyman71
United Kingdom 2008 Range Rover Vogue TDV8 Java Black
The pump for the fbh gives a metered amount of fuel to the burner you shouldn't bypass it as it may be possible for the burner to carry on drawing fuel!!
Post #298702 12th Dec 2014 10:52pm
Scottyav
The fBH doesn't run at all now without the other plug connected which is fine Thumbs Up _____________________________________________________
Post #298713 13th Dec 2014 5:24am
