Home > Maintenance & Mods (L322) > Frozen Out |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3646 |
Went to car all doors frozen shut, because I no longer have a diesel no FBH.
13th Dec 2014 10:01am |
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 |
Gummi pflege |
13th Dec 2014 10:04am |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16171 |
Lube up... Should be used to that with an SC sir |
13th Dec 2014 10:11am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34924 |
13th Dec 2014 10:29am |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7634 |
You guys make your cars live outside ? Wow.......
13th Dec 2014 12:08pm |
ironhorse Member Since: 13 Dec 2013 Location: birmingham Posts: 355 |
motorbikes live in heated garage
13th Dec 2014 1:04pm |
Bikes should live inside (when not in use obviously) and cars ideally as well if the garage has enough space. But I do prefer to have a workshop more than a garage for a car, so if there is no other option, the car out and workshop (and bike) inside.
13th Dec 2014 1:22pm |
If you can't get Gummi Pflege, talcum powder is a cheap and easy alternative. MY 2010 5.0 SC Galway green and sand interior!!
13th Dec 2014 1:30pm |
Thanks all
13th Dec 2014 4:22pm |
I'd start with the bay of E. |
13th Dec 2014 5:34pm |
http://www.ebay.co.uk/itm/Einszett-gummi-p...5413f47e2c
13th Dec 2014 5:46pm |
i agree must be used: heated garage to take the chill off it when you return |
13th Dec 2014 6:37pm |
noworries4x4 Member Since: 03 Oct 2013 Location: Newton Abbot Posts: 156 |
My P38 just used to squeeze in my workshop hit the wall with the towbar and bend the spots back a bit to shut the door mm's to spare, the L322 no chance !! If everything is under control you are not going fast enough.
13th Dec 2014 6:55pm |
Gummi pfledge ordered and will go in the boot with the rest of the assorted paraphernalia👍 There is nothing that can't be fixed with a hammer😜😜
13th Dec 2014 7:00pm |
