Home > Technical > Sloshing Water Sound Behind Dash???
England 2005 Range Rover Td6 HSE Auto Cairns Blue
nice result...even if the water does leak back in , at least it can now drain out and give you peaceful motoring... ..............................
this is handy Wink
Post #34324 29th Oct 2010 7:31pm
802965118
United Kingdom 2002 Range Rover Td6 Vogue Auto Epsom Green
Superb result............I will attempt mine but can’t tell from your picture exactly where you drilled, did you have to remove anything to get a drill in as I have the battery on the passenger side the air intake in the middle and the wiper mechanism on the driver’s side and don’t seem to have the space your picture shows............
Post #34353 29th Oct 2010 11:52pm
CyberMrT
2003 Range Rover 4.4 V8 Vogue Auto Stornoway Grey
I'll take some more pictures to show the location and what needs removing. L322 2002 4.4 V8 LPG
Post #34373 30th Oct 2010 9:28am
802965118
Hi John , well took the decision to remove the air intake box which was more simple than expected ...........this gave plenty of room to get a drill in to drill the holes, ........i did two one either side and out poured the water ...great result. I also took the opportunity to clean in and around the air intake box which is just a bit of OCD kicking in according to the wife but made me happy........I can’t thank you enough for pursuing this issue which has become a most gratifying fix and for me at no cost as i did all the work myself today.
After putting it all back together i took the Rangy for a drive along a route that had plenty of hills, mini roundabouts and bends so within minutes the Rangy was as quiet as could be no water noise at all.
When i drilled the holes each side i also drilled them out to 10mm so water can drain with ease which has worked a treat
Many thanks again
All the best Steve
Post #34431 30th Oct 2010 8:33pm
elpeede
England 2003 Range Rover Td6 Vogue Auto Zambezi Silver
Shocked Thats not the Wiper housing.. thats the coolant chamber for the flux capacitor. If its splooshing it need to be topped up! Shocked
Wink 2008 Nissan Pathfinder Mammoth Sport - "Rory", 1990 110 TD CSW - "Snowy" - 2005 Freelander TD4 S - "Freddie"
Previous Landrover products - 2003 TD6 Vogue - "Jeeves/Big Bill" (Depends on mood!) - RRC TD Vogue - "Alfie", RRC v8 Fleetline "Reggie", Disco ES V8 LPG "Oscar", 101 Ambulance prototype - "Morph", 1964 SIIa Auto Powered by Jag 4.2 Lump - "Percy".
Post #34446 30th Oct 2010 9:59pm
