Home > Maintenance & Mods (L322) > WARNING change your diff oil!!! |
EmiratesA380 Member Since: 14 Jan 2015 Location: england Posts: 350 |
Its a piece of mind knowing that its not all on the floor back up the road. I am not sure if stealers change this when they do a oil change ? - I presume they just plug the hole with the old one. I like to know my holes filled - say no more |
20th Feb 2015 10:28pm |
pld118 Member Since: 25 Mar 2013 Location: Bairns Posts: 4218 |
Our recent service invoice says they put a new oil plug in for the engine oil change |
20th Feb 2015 10:33pm |
Quote: " Our recent service invoice says they put a new oil plug in for the engine oil change "
20th Feb 2015 10:36pm |
Hears a question to all
20th Feb 2015 10:45pm |
No idea but we had 4 tyres fitted at the same time and the rears are wearing quicker. |
20th Feb 2015 11:11pm |
Didn't some one say they were splash lubricated ? 2008 MY Supercharged Rimini Red / Jet four zone climate remote park heater and no ugly kid windows. magnus satis quod turpis satis |
21st Feb 2015 12:56am |
Hi Axle
21st Feb 2015 8:38am |
I said I would keep an eye on this and a couple of months later I have 54% travel left , something is going away it seems . 2008 MY Supercharged Rimini Red / Jet four zone climate remote park heater and no ugly kid windows. magnus satis quod turpis satis |
10th May 2015 11:48am |
Well, I've placed an order with Dan @ Duckworths so that I can change the following, as the 4.4TDV8 is touching 30k miles:
31st Oct 2015 7:42am |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2301 |
Karcraft in Sydney stock the oil but can be out at and given time, such as when I wanted some for my D4 although their new stock arrived in time. At this stage I don't know whether I'll retrofit/convert an e-diff to the RRV but the oil for the open diff is available locally from any Castrol supplier. |
31st Oct 2015 11:30am |
kezbo1981 Member Since: 20 Jan 2015 Location: Evesham, Worc Posts: 334 |
I tried to find this today, but it's not listed in my live values. Is it vehicle specific or have you got a different version of iid to me? |
1st Nov 2015 7:22pm |
The clutch travel remaining should be there but I see your's is a 2006 so I assume its a pre facelift supercharged , don't know if that means anything . I have have an ordinary and non bluetooth iiD and they both showed clutch travel . Since changing my oil clutch travel available has stabilised at 54% so old damaged/contaminated oil is clearly very damaging . 2008 MY Supercharged
2nd Nov 2015 2:35am |
Changed the rear Diff Oil this afternoon and re torqued the drain plug at 54nm and the fill plug 34nm.
8th Nov 2015 6:53pm |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 |
There are two figures in the manual (at least in the older ones there are)
8th Nov 2015 10:30pm |
