![]() | Home > Technical (L322) > Rear Wiper Blade Replacement |
vaz Member Since: 15 Jun 2014 Location: Colne, Lancashire Posts: 332 ![]() ![]() ![]() |
If its like a P38 Range Rover, set the wiper on and go to the back door. When the wiper is halfway down the screen, open the top tailgate, it should stop where it is, then you can change the blade.
Had the same f-ing problem Andy, haven't found the solution yet (the car is not here). So looking forward to what you turn up for answer |
Andy B Member Since: 03 Apr 2012 Location: West Malling Posts: 1223 ![]() ![]() |
Cheers Steve, I'll give that a go! I'll post an update Eugene ![]() SDV8 VSE MY 2015 - Gone 5.0 S/C AB MY 2010 - Gone 4.2 S/C VSE MY 2006 - Gone |
Thanks Steve, worked a treat. |
Mark L Member Since: 29 Oct 2014 Location: Tamworth Posts: 121 ![]() ![]() ![]() |
I did it the hard way and took the roof spoiler off... |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35767 ![]() ![]() |
you boys with these modern FF's do suffer dont you |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
Yep, pre 09 turn off the ignition mid sweep and post 09 open the top tailgate mid sweep... |
sasdiscos Member Since: 16 Oct 2014 Location: Northants Posts: 286 ![]() ![]() ![]() |
Ill keep that piece of info, thats what you learn on forums. |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2281 ![]() ![]() ![]() |
Anyway thought all you rich chaps had butlers to do that ![]() ![]() |
My Butler runs my house, my Valet runs my wardrobe and my Driver runs my car |
Used to be rich...then I brought a Full Fat! ![]() ![]() SDV8 VSE MY 2015 - Gone 5.0 S/C AB MY 2010 - Gone 4.2 S/C VSE MY 2006 - Gone |
