Home > In Car Electronics (L322) > How to... Fit Android Head Unit to 2002-2005... |
UK Marine Member Since: 22 Jul 2016 Location: Durham, County Durham UK Posts: 816 |
That’s what I get for butting into a thread three quarters through
28th Jan 2018 8:03pm |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
Oh I know that there's some smug git with the answer... I just haven't found em yet
28th Jan 2018 8:54pm |
pietertje Member Since: 30 Nov 2014 Location: Rotterdam Posts: 152 |
Here is my setup.. I just finished installing the GA8201A with 5m extension and it works great with the DSP (old head unit in the glove box). Also added DAB+ which is really great. The BMW-IBUS app (discussed here: http://www.fullfatrr.com/forum/topic44779.html) is a really great add-on to this head unit and gives lots of extra functionality to the car (f.e. coolant temp. visable in OBC as you can see on the photo). I will make some better photo's tomorrow. The head unit fits nice in the dash and looks really OEM. Still in the progress of tackling one very annoying problem though; Cold start it takes forever to boot and the unit keeps hanging at the first boot screen. Already received several firmware updates from supplier (EONON) but problem hasn't been solved yet. Only when I press reset after several minutes the unit will boot correctly. 2002 L322 V8 |
28th Jan 2018 11:50pm |
goldwing Member Since: 04 Mar 2018 Location: Birmingham Posts: 3 |
Unnecessary quote removed
4th Mar 2018 4:20pm |
Yes, Eonon had offerde Fred replacement of the head unit. I Will use this service.
6th Mar 2018 10:52am |
Nigelpugh Member Since: 16 Mar 2018 Location: Solihull Posts: 21 |
Hi Guys,
3rd Apr 2018 8:39am |
I have fitted the Eonon 8201A great unit does everything, but i could not get it to run for more than 20 seconds, after following all the advise from Eonon they replaced the unit but the only way it would work is with the original head unit intact. I put my unit under the front passenger seat so didnt have to remove the cd multichanger and all works great and still have the use of onboard computer system. |
3rd Apr 2018 11:15am |
Thanks goldwing.
3rd Apr 2018 12:20pm |
No problem ask as much as you need to i will help in any way. Even with the the long wiring loom it seems that the eonon unit did not trigger the DSP amp so would keep the amp alive. I did try a few options to keep the amp alive by powering different wires but none worked. I could find a decent car sparks local who did not want to charge me a £100 an hour to try and figure the issue out. |
3rd Apr 2018 12:46pm |
Thanks goldwing! I’m sure I will have lots of questions!
3rd Apr 2018 2:58pm |
bobsin Member Since: 21 May 2015 Location: wolverhampton Posts: 50 |
You do need the old headunit connected, it interacts with the BM54, (via i-bus), which is only used to keep DSP awake, otherwise it will shut down once DSP receives no keep awake signal via the I-Bus, which is generated in the bm54. Audio out from the bm54 is not used or connected to a load, Audio out from the EONON is connected as input to the DSP, via the long front-to-back lead.... Glovebox is best place to site old head, as the leads reach there - just!!
6th Apr 2018 3:04am |
Ottar Member Since: 07 Jun 2016 Location: Bekkestua Posts: 8 |
I’ve read all the different pthreads on this theme, both here and on Rangerovers.net.
15th Apr 2018 9:48pm |
17th Apr 2018 12:22pm |
nobody help me out to work out the bm54 unit? |
19th Apr 2018 11:16am |
