Home > Technical (L322) > Dreaded Flat Battery |
Fish Member Since: 30 Aug 2014 Location: Bolton Posts: 301 |
I went to the car today which has been stood since Weds afternoon and it wouldn't start. The doors opened ok and everything lit up and it tried to turn over but there wasn't enough juice. I tried my booster but the clips won't fit on the terminals so I out the charge on it but after 10 hours it still won't turn over. I think I may need a bigger / better charger!
27th Dec 2014 11:56pm |
Thanks,
29th Dec 2014 9:42am |
Well it's been on charge all day again with the old charger but no improvement. The new ctek has arrived and been connected now. When I plugged it in the indicator showed it completely flat and when I check just now it had moved to the next one up so hopefully that's a good sign. Maybe the old one wasn't working properly.
29th Dec 2014 9:22pm |
Have you checked the battery terminals and the +ve jump post terminals are all tight?
29th Dec 2014 9:27pm |
Fish fill in your car profile bits
29th Dec 2014 11:26pm |
Thanks guys.
30th Dec 2014 8:09am |
Well, good(ish) news. Checked the battery and it was indicating fully charged and it started first time. When I put the multimeter on with the engine running it was only showing around 11.9v. Is this because it's been flat or it's on tickover? It should be 14.2v or more shouldn't it?
30th Dec 2014 8:51am |
You may have LED's in the sidelights which flash occasionally due to the cold/hot monitoring. Mine flash at the same time though.
30th Dec 2014 11:16am |
From what you describe I doubt there is anything wrong with either your battery or alternator.
30th Dec 2014 11:34am |
Sorry guys, I tried to set my profile earlier on the ipad but it wouldnt let me. I ve done it now though on the laptop. I have a 2007 TDV8 Vogue.
30th Dec 2014 2:24pm |
PaulTyrer Member Since: 22 Jul 2013 Location: Devizes, Wiltshire Posts: 1227 |
Just a thought, is the cover where the diagnostics plug into closed? I read on one thread here that if it is left open it can cause a drain on the battery, or was I dreaming? |
30th Dec 2014 3:38pm |
And hey Fish! you have a red one .
30th Dec 2014 4:27pm |
Yes Joe, I like to be different, none of this silver / grey malarkey
30th Dec 2014 4:51pm |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2026 |
my kids leave the roof spotlights on sometimes... |
30th Dec 2014 4:54pm |
