Home > Maintenance & Mods (L322) > Rear Led Tail light conversion wiring thought |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
I have a broken rear light , I got a replacement s/h rear light and it didn't want to go on I pushed the light and it's now more broken than the original
5th Jan 2015 7:51pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34916 |
i think its more complicated than that and these resisters do get hot if left on for a while...afaik there's a constant live which is switched by impulses from the ecu when each light is required...
5th Jan 2015 8:11pm |
Yes I was looking at the clear super changed one's, but I'd probably break them too The later led's will be hard wired so there will be no problems with bad contacts, plus they look nice
5th Jan 2015 8:42pm |
craig does a lot of conversions and he might be able to give some expert thoughts on the 'adapters' for the 2010/12 led lights.. ... - .- -.
5th Jan 2015 8:45pm |
Are but that will cost me £650 fitted
5th Jan 2015 9:01pm |
Sorry Stan, we haven't, don't and won't fit resistor kits |
5th Jan 2015 9:51pm |
So from that I can assume that you've some way of reprogramming on the board monitoring system, and what sort of damage would we be talking if I were to fit the lights and you make 'em work Yesterday I couldn't spell Engineer... Today I are one!
5th Jan 2015 10:00pm |
Rear light prices are on the website sir |
6th Jan 2015 1:47am |
horse86 Member Since: 09 Dec 2014 Location: PA Posts: 860 |
scored a set of 2012 tails for $525 shipped. Looking forward to the update this weekend |
6th Jan 2015 6:05pm |
Having read lots of posts about light fitting, and different voltages, I have decided to go the Supercharged route. Mainly because I know that a FFRR is sensitive about electrical changes, and I wouldn't want to upset the apple cart, so to speak
6th Jan 2015 6:49pm |
Just a thought, do you think it's wise to employ some epoxy resin and go over all the seams before fitting them, or should I take a chance that I've got the only fully sealed set to come from the factory ? Yesterday I couldn't spell Engineer... Today I are one!
6th Jan 2015 6:53pm |
