Home > Maintenance & Mods (L322) > Gearbox flush - Apologies
J90
France 2006 Range Rover Vogue Td6 Java Black
I was on eBay looking for a vortex crankcase breather filter and stumbled across a full gearbox flush for £260, no mention of the filter being changed.
I had my gearbox filter and oil changed approx 10K miles ago and it cost me £280. Obviously some of the old gearbox oil remained.
So here's my question, next time I decide to change the gearbox oil should I have a full flush or another filter and oil change.
I value your thoughts. Thanks Travelling around in circles again.
Post #303077 6th Jan 2015 12:29pm
as the gearbox's are supposed to be 'sealed for life' , any oil change with new filter can only help in preventative maintenance...
i wouldnt worry about any small amount of old oil left as it will soon mix with the new stuff.. ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
workshop manual downloads are in our wiki
Post #303078 6th Jan 2015 12:32pm
Don't know if this helps.
Post #303087 6th Jan 2015 1:08pm
J90
Thanks Kurt Thumbs Up Travelling around in circles again.
Post #303145 6th Jan 2015 6:27pm
jon3929
United Kingdom 2005 Range Rover Vogue Td6 Zambezi Silver
J90
Can I ask what your gearbox oil change experience has been?
I bought a MY05 TD6 9 months ago and it is now on 113k miles and the gearbox appears fine. Its soon going in for the first service in my ownership and i'm trying to establish whether to fiddle with the gearbox by changing oil and filter or not Shocked
Was there any noticeable affect? and did you reset the EAT ECU or was it simply ok as was?
Thanks in advance, Cheers, Jon.
Post #304119 10th Jan 2015 9:56pm
Mikey
mzplcg wrote:
Something to point out here though. That "Filter" which everyone's going on about is actually a STRAINER !!
Think about the engine oil .................................................................
I cut my own filter open (Disco 3 6 speed ZF) after 115k miles, and the strainer was clean too. It's not a filter as we think of filters Thumbs Up
The strainer is there to catch big lumps. If you have big lumps floating around your gearbox, you would certainly know about it Shocked
It is advised by ZF, that the 6 speed and 8 speed boxes are FLUSHED between 50-75k miles.
As said, I changed mine at 115k miles. It has just ticked over 150k miles now, and the gearbox is Censored
Post #304131 10th Jan 2015 10:50pm
J90
Jon3929, I changed my gearbox filter and oil at 56k. It did feel smoother and quicker as a result. I'm coming up to 70k now and will either have a 'flush' or another filter and partial oil change sometime before reaching 75k as further preventative maintenance. Travelling around in circles again.
Post #304142 11th Jan 2015 12:39am
gregdav
England 2005 Range Rover Vogue Td6 Bonatti Grey
Hi jon3929, had my gearbox oil and filter changed at 119,000 mls, certainly made a difference, much smoother through the gears.
has your gearbox been changed, as mine was changed at 75,000 mls by last owner.
greg.
Post #304157 11th Jan 2015 7:19am
jon3929
Thanks - I believe the gearbox is original.
I cant help feeling that an oil change would 'only do good' but clearly that's not the advice of the manufacturer.
Driving it earlier (and admittedly being super critical) I think its snatches a little bit in the lower gears but it really isn't an issue.
Just trying to work out whether to do the drain & refill or 'leave well alone cos it aint broke'! Shocked Thumbs Up
Cheers, Jon.
Post #304218 11th Jan 2015 5:34pm
