![]() | Home > Maintenance & Mods (L322) > 2014 - what did you use your IID tool for? |
KurtVerbose Member Since: 08 Aug 2010 Location: Les Arses Posts: 5848 ![]() ![]() ![]() |
Mine's still in the box.
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3268 ![]() ![]() ![]() |
Fault reading and clearing.
steptoe Member Since: 23 Jul 2012 Location: london Posts: 382 ![]() ![]() |
Turned off the automatically retracting steering column.
Martyn Member Since: 10 Mar 2013 Location: Poole Posts: 65 ![]() ![]() |
I've used mine to scan and clear the codes on a couple of friends vehicles (Disco 3 and a 4.4 FFRR) and also monitor the coolant temp after a thermostat replacement. Great tool to keep in the car |
sasdiscos Member Since: 16 Oct 2014 Location: Northants Posts: 286 ![]() ![]() ![]() |
Turned on the digital speedo.
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1901 ![]() ![]() ![]() |
IId tool so far has
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8713 ![]() ![]() ![]() |
Always playing with mine, it's saved a fortune in garage bills, lots of help when fault finding, calibrated the EAS, saved separate settings for off roading... tuned the CCF to my personal taste, and read and cleared faults on other peoples FF
fanders Member Since: 10 Jul 2013 Location: Hants, UK Posts: 318 ![]() ![]() ![]() |
Turned off the TPMS |
verydisco Member Since: 10 Dec 2009 Location: UK/US Posts: 2952 ![]() ![]() ![]() |
I am sure I will forget some, but here you go:
IanT599 Member Since: 15 Jun 2013 Location: Wellington Posts: 351 ![]() ![]() |
Hi verydisco
The digital speedo is in fact an extra indication of speed in didgits, on the side of the needle, just browse the IID tool options list
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6424 ![]() ![]() |
Not much, checked faults a couple of times, and live value of gearbox oil temperature when refilling after fluid and filter change. They do become reliable over time (if you replace enough of the bits!) |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8760 ![]() ![]() ![]() |
Am liking that LR branded flight case a lot. Where can I get one!!!! |
Was thinking the same thing myself. Just need a smaller one for just the IIDtool |
