Home > In Car Electronics (L322) > Bluetooth music in 2011 FFRR? |
DMRR Member Since: 14 Apr 2010 Location: Northamptonshire Posts: 2027 |
There's an iPod connector in the cubby box, big socket .... you need that lead and 'shock horror' it's not cheap (read - RIP OFF) Land Rover Addict
14th Jan 2015 10:27pm |
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1651 |
Thanks both
14th Jan 2015 10:54pm |
Be aware early ones WILL NOT CHARGE your ipod/iphone if its 3GS era and below (no really!?!) Land Rover Addict
14th Jan 2015 11:53pm |
B9er Member Since: 10 Dec 2012 Location: Larne Posts: 191 |
Check out the following topic re bluetooth music streaming.
15th Jan 2015 6:46am |
Why don't you put all the music on a (big) USB stick. That you can leave in the USB slot and it can be controlled from the steering wheel etc. Just make sure that you have a "clean" set of folders, as it hidden info will slow down operation as Geoff recently found out . http://www.fullfatrr.com/forum/topic29293.html?highlight=usb MY 2010 5.0 SC Galway green and sand interior!!
15th Jan 2015 7:01am |
Johnielle Member Since: 04 Oct 2017 Location: New York Posts: 1 |
I have been using BT adapter to stream music via bluetooth. I have the viseeousa 1000 plugged to my 30 pin range rover iPod cable. Works really good, no issues. |
4th Oct 2017 4:02pm |
