Home > Maintenance & Mods (L322) > handbrake light on dash flashing
Lad
England 2010 Range Rover Vogue SE TDV8 Santorini Black
The other day I was setting off from work and when I started the engine I noticed the handbrake warning light was flashing. There were no bongs or other warnings. It disengaged properly and when I got home it applied without bongs and warning light didn't flash. I was just wondering what could have caused it. Owt to worry about?
Post #303493 7th Jan 2015 9:16pm
3528cc
United Kingdom 2008 Range Rover Autobiography 4.2 SC V8 Buckingham Blue
Are you sure it was applied, I have forgotton to put my HB on an couple of times Embarassed , but transmission was in park, when you turn the ignition on the light flashes Embarassed Regards
Royston
2008 4.2 Supercharged Autobiography
1994 Classic Vogue SE
1999 Rover BRM
1987 Rover Vitesse Twin Plenum
Post #303495 7th Jan 2015 9:19pm
Lad
Hhhhhmmmmmmm. I'm sure I did, as I park on a steep hill in the car park at work. The gear lever was easy to move to drive. I'll try it without appling the handbrake and turn off and then back on and see if it flashes.
Post #303496 7th Jan 2015 9:24pm
Katash
England 2007 Range Rover Supercharged 4.2 SC V8 Zermatt Silver
normally means a EPB fault - I get it sometimes after I've been jacking the car up and removing the wheels, had it the other day for the first time after doing no DIY - just need to release and re apply to clear
If it doesn't clear there is an EPB emergency release cable in the boot you can use.
Post #303525 7th Jan 2015 10:51pm
DMRR
Be aware - if you have enabled DRL's (side lights vs main beam) they will also flash (rears)......which can confuse other road users!
Normal reason for this error is either - system jammed or, as was my case, wading way too deep!!!!
https://www.facebook.com/video.php?v=10151...7619268304 Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #303528 7th Jan 2015 10:56pm
Lad
No DRL's enabled. No stored DTC's either. I was wondering is there a setting that with auto apply the handbrake when switching off the engine? Like on the disco. There, if you want to keep the handbrake off you press the handbrake switch in the off position while you switch off.
Post #303542 7th Jan 2015 11:38pm
DMRR
Nope, or at least there wasn't when I had a 2010.....
My 2010 suffered like yours but only after deep wading, so might be worth getting under there and checking the connectors are snug (rear axle - top)
[EDIT] - Low battery also did this on mine...... Land Rover Addict
Previous
XXXXXXXXXXXXXXXX
2004 4.4V8 Vogue
Post #303543 7th Jan 2015 11:40pm
Lad
Not been wading since ive had it. It's had the recall (q159) but ( in my opinion) I think it's still on its way out. I've had the battery checked at the dealer and they said it was ok. It did cross my mind that the battery may cause it but dismissed it. It runs the FBH no problems, and starts ok but I've noticed on a few occasions that when I start the car the radio doesn't come back on straight away Whistle
Post #303545 7th Jan 2015 11:45pm
Is the handbrake warning lamp separate from the braked wear lamp?
Post #303589 8th Jan 2015 10:07am
check the brake fluid level but i think its more likely a low voltage battery on a cold day.. ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
workshop manual downloads are in our wiki
Post #303591 8th Jan 2015 10:21am
Lad
It was flashing before I started the engine and carried on after the engine was started and until I released the handbrake.
Me thinks I may need a new battery.
Post #303785 9th Jan 2015 12:05am
Ajay(UK)
United Kingdom 2015 Range Rover Autobiography SDV8 Indus Silver
I sometimes get this when parked on my drive which is on a slope. I can't see you needing a new battery though as I have been getting this every now and then ever since I have had the car (4 years) before and after the battery recall. Rolling Eyes
My guess is it's more to do with parking on a hill but there are no error messages in my faultmate and as it's very occasional so I'm putting it down to a "characteristic" of my car Whistle
Andy. 2015 L405 SDV8 Autobiography, Indus Silver with Black Pack.
SWMBO: 22MY Defender 110 HSE X Dynamic, Gondwana Stone.
Gone: 2014 Discovery 4 HSE Luxury Firenze Red
Gone: 2006MY Java Black TD6 Autobiography
Gone: 2013 Jaguar XKR Convertible, Italian Racing Red with Ivory Seats
Gone: 2010MY Stornoway Grey TDV8 Vogue SE with RSE
Gone: 2008 Disco 3 HSE, Hybrid Tv + Retro-fit RSE System & DVD
Gone: 2003 Epsom Green 4.4i Vogue, LPG, Mk4 Nav, BMW Bluetooth Phone, Hybrid Tv Tuner,
Post #304425 12th Jan 2015 2:15pm
Lad
Keeping an eye on it as I park in the same place at work every day. It's not flashed since. He says touching wood as I type. Whistle
Post #304613 12th Jan 2015 11:31pm
