Home > In Car Electronics (L322) > CTEK and GAPiiD |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3195 |
Don't know whether this is the right place. If not can you move it please, Stan?
15th Jan 2015 1:30pm |
Martin Site Admin Member Since: 24 Mar 2007 Location: Hook Norton Posts: 1665 |
You need a charger with a "supply" function - the manual for the MXS 7.0 will tell you if it has this (off the top of my head it doesn't) |
15th Jan 2015 1:51pm |
Thanks for that, Martin. Will have a look. John
15th Jan 2015 2:02pm |
Martin, From the CTEK website for the MXS7.0 " It also has a power supply mode which allows the battery to be disconnected from the vehicle without losing important configurations. " Would that cover the requirement? John
15th Jan 2015 2:07pm |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1695 |
The 7 will be fine, providing your battery is fully charged, and in good condition to begin with
15th Jan 2015 8:10pm |
Thanks for the replies. I have ordered an MXS7.0 as I needed an up to date charger anyway John
15th Jan 2015 8:12pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7635 |
I have the ctek 7 charger and an IID tool. Why does it take 70 mins ? Admittedly I have Navcoder and it takes less than 10 seconds to select the option and send to unit.
16th Jan 2015 6:58pm |
It takes 70 minutes to re-write the firmware to the Nav screen |
16th Jan 2015 8:48pm |
So it's a firmware upgrade rather than just a setting change ?
16th Jan 2015 9:34pm |
There is a CCF edit, which takes around 30 seconds, then 2 large firmware updates, at around 35 minutes each
17th Jan 2015 10:23am |
