Home > In Car Electronics (L322) > radio not working |
cowman Member Since: 24 Jul 2013 Location: United Kingdom Posts: 186 |
started car up today the head unit lights up with landrover logo no radio ,no tv and no sat nav ,if i press the on /off button it wont switch off, has anyone had this trouble ,is it a simple fix. |
17th Jan 2015 7:55pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34929 |
battery? ... - .- -.
17th Jan 2015 8:31pm |
new varta battery 6 mths ago |
17th Jan 2015 8:55pm |
maybe this,
17th Jan 2015 11:07pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16176 |
We have had a lot of rain sir...You sure your boot seal is not leaking over the BT module or worse sir... |
17th Jan 2015 11:42pm |
Ianmaney Member Since: 27 Nov 2012 Location: Birmingham UK Posts: 118 |
I had this a few months ago, i just pulled all the plugs from the amp, left it for 5 mins and plugged them all back in, worked a treat, burst into life straight away, i also used to have this on me 06 X5 so maybe its an inherent fault ?? |
18th Jan 2015 7:03am |
thanks for all the advice it is dry in the back ,i will have a look today and let you know. |
18th Jan 2015 11:23am |
had a look today did the mod stan suggested and it works radio ,telly and cd player the only thing that doesnt work is the hands free,took the bt apart and there was condensation inside so water has got in ,but not wet anywhere else ,so i need a bt module now at a sensible price ,thanks for all the help spot on . |
19th Jan 2015 7:53pm |
