Home > Maintenance & Mods (L322) > Rear window (vertical) rubber strips
comports
Hi All,
My rear window strips (the vertical ones) have started to rust at the bottom. Having received some new strips from Dan, I was just wondering if they are a straight pull off and push on affair (like the rubber door seals) or are there parts I need to remove/refit..
Anyone done this already before I go and break something or spend 4 hours on a 5 minute job?
Thx Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #307020 22nd Jan 2015 11:39am
pietertje
Netherlands 2002 Range Rover Vogue 4.4 V8 Java Black
Hi Comports,
I just changed my weather strips this last week because of the same issue, rust. Mine were pretty bad.
It's a pretty forward operation. I lifted them up on one side with a flat screwdriver, covered in a cloth to avoid scratching my bodywork. They come of pretty easy once you have lifted a corner. The new ones I just hammered in with my hands.
Good luck.
Post #307023 22nd Jan 2015 11:49am
anyone know what these strips are for? ... - .- -.
Post #307024 22nd Jan 2015 11:51am
pietertje
Main function is to support your local stealer I think.
Post #307025 22nd Jan 2015 11:52am
Laughing excellent ... - .- -.
Post #307027 22nd Jan 2015 11:56am
comports
are we talking about the same thing here.? mine have sticky pad "tabs" at right angles sticking out from the top and bottom to attach to something? Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #307148 22nd Jan 2015 7:43pm
pietertje
hmmm...
Can you post a picture of it?
Post #307149 22nd Jan 2015 7:45pm
verydisco
He is talking about these rubber strips (42430 on diagram), only fitted on 2009-on.
I took mine off as they rusted (only 2 year old!) and have been provided with 2 new ones to fit. (they just slide out on the side, no tools needed.
I am just not sure how to slide-in the stick-on bit at the bottom once you take the masking tape off Neutral l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #307159 22nd Jan 2015 8:07pm
comports
That's the one VeryDisco...
I can feel a wiki "how to" coming.. Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #307371 23rd Jan 2015 1:08pm
verydisco
I imagine they are here to ever so slightly reduce wind noise.
it does look better without them. Since I have them in stock I will most likely put them on and report if they do make any difference. l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #307409 23rd Jan 2015 2:35pm
Triarii
United Kingdom 2017 Range Rover Autobiography SDV8 Corris Grey
One of my first jobs.
Do these have aluminium in them? Mine had what looked like HAO residue at the bottom.... 17 MY Corris Grey 4.4 VAB
Silver MB R231 SL350
Post #319091 22nd Mar 2015 7:58pm
verydisco
YEP, THEY DO Censored l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #319106 22nd Mar 2015 9:30pm
comports
HI VeryDisco,
Did you do yours in the end. I fitted mine but like you could not find a way to stick the tabs as they fit behind the glass.
As it happens LR kindly offered to fit a new upper tailgate 2 weeks after I tried mine and fitted new ones as part of the service. I think the window has to come off to locate the sticky strip correctly. Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #319125 22nd Mar 2015 11:01pm
verydisco
yep, no way the tabs are going in once you peel off the sticky tape strip. Any tips guys?
tx l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #319127 22nd Mar 2015 11:04pm
Fatzo
France 2011 Range Rover Vogue TDV8 Ipanema Sand
Sorry for upping this, since I'm interested in the "how to":
- remove the strips (they seem tight fastened)
- put back new strips
I believe I can't do this by myself, but I also believe it's not compulsory to ask a LR dealer do it too...
Thanks for your advices
Fatzo
Post #414461 20th Nov 2016 12:05am
