Home > Maintenance & Mods (L322) > TD6 VORTEX CRANKCASE FILTER
AKIS
2004 Range Rover Vogue Td6 Cairns Blue
Quite confused with it.
Have seen a lot of you have replaced filter with the new vortex type 11127799367.
From what i can see is filter on the bottom left fin left has a "cut"which should be aligned with the housing "line driver"in order to straight be placed in housing
Problem is that i tried to fit this filter but under no way filter's fin cut and housing line driver can be aligned
I have also seen that some other have fitted the 1112779922,which quite different from the 11127799367 since it has on a different position the fin cut and still plug and play
How this can be possible?unless if is not necessary fin "cut" and housing "line driver" to be aligned which means that no problem if filter will not be in straight but with a small bend to the right side (leaving on left side a gap between filter's bottom and housing)
Any idea please
Post #308469 27th Jan 2015 1:14pm
Weegie
The one I fitted was 11127799224 which is the complete unit and is a straightforward replacement. John
GAP iiD BT
Post #308483 27th Jan 2015 2:07pm
AKIS
John many thanks for your reply.I have bought the 11127799224 but filter is lying in the housing with a small bend since the small cut which filter has on the left side fin is not aligned with the line driver the housing has and i donot know is might be any problem because of it
Post #308791 28th Jan 2015 5:25pm
