You can't use cheap stuff to flush it through, about 1/2 the fluid stays inside so all you will do is add a quantity of the wrong oil in the box...
You need the temp of the oil, not the temp of the sump, which is metal not plastic, this will take some time to get to the temp of the oil within, it's better than nothing but not ideal....
Make sure you can undo the fill plug before you drain and remove the sump to change the filter, if you can't get it off, and it can be very tight, then your stuck. Don't take it all the way out with the engine off as a couple of ltrs will end up all over you.
Use a genuine filter, and a new gasket on the sump... Pete
