Home > Technical (L322) > How do the Adaptive light work? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34920 |
question craig, if you have a 2010/12 facelift done ,do you loose the AFS? ... - .- -.
4th Feb 2015 3:47pm |
Swiftman Member Since: 23 Jan 2013 Location: Midlothian Posts: 128 |
yes that's correct headlamps rise up when switched on |
4th Feb 2015 4:02pm |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6658 |
^^ I've been advised that even with facelifted AFS headlights, they don't work on an earlier car Stan. Got - 2017 SDV8 Autobiography in Loire Blue
4th Feb 2015 4:03pm |
thanks alan.. ... - .- -.
4th Feb 2015 4:08pm |
Take a look here Stan http://www.rangerovers.net/forum/9-range-r...ash-2.html
4th Feb 2015 4:22pm |
4th Feb 2015 4:34pm |
DMRR Member Since: 14 Apr 2010 Location: Northamptonshire Posts: 2027 |
Just looked at my build list and see this :
4th Feb 2015 4:40pm |
if you have that neil then you should have afs according to the WM,
4th Feb 2015 4:52pm |
...so mine is either OFF or duff? I must investigate
4th Feb 2015 4:56pm |
Time to check this ..... maybe?
4th Feb 2015 5:03pm |
i only ever had one problem with mine and that was after i took the headlight unit out but even then i had an error come up on the dash as i hadnt fully pushed the headlight plug in..
4th Feb 2015 5:06pm |
I don't think you have AFS headlamps... I think all 06> have electronic levelling but only VSE's and AB's had AFS as standard...
4th Feb 2015 5:09pm |
I would have expected an error on the dash if the fuse had one, since the criss-cross light pattern is when the ECU checks the position of the headlights. Got - 2017 SDV8 Autobiography in Loire Blue
4th Feb 2015 5:10pm |
Yes Stan, you loose it as 09> Headlamp AFS are LIN BUS pre 09my are CAN BUS and never the twain shall meet! |
4th Feb 2015 5:11pm |
