Home > Maintenance & Mods (L322) > Lower control arm
Rob
Ireland 2005 Range Rover HSE Td6 Java Black
Lower control arm
hi just enquiring my full fat failed test on lower ball joints have new control arm on the way is this a job I can tackle my self. Cheers guys
Post #311439 7th Feb 2015 11:26pm
Depends how good/confident you are with the spanners, and that you have the right spanners!
The lower ball joints at the front end can prove to be difficult to remove, you may have to damage the existing to get them off!
There are howtos in the wiki Thumbs Up .
Post #311455 8th Feb 2015 1:04am
Welshdragon
The lower ball joint, the one pressed in the hub can be done but it's right pita to do, I have recently just changed mine, I took mine to local garage to sort as they would not budge.
The other one, ball joint pressed to the arm is an easy job, but you will damage the old one when 'tapping Whistle ' it off to change. If it dont work.......burn it!
Post #311492 8th Feb 2015 11:35am
