![]() | Home > In Car Electronics (L322) > Cubby box 12v socket |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35793 ![]() ![]() |
you cant make it permanent unless you re-wire it....the boot one is permanent live and you could run a feed to the front.. ... - .- -.
Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804 ![]() ![]() ![]() |
The 12v sockets run through relays, that's why they normally only become live when the ignition is on.
J90 Member Since: 02 Jul 2013 Location: Somewhere south of Bergerac Posts: 651 ![]() ![]() ![]() |
Thanks for the swift replies guys. I'll have a think about running a feed from the boot socket to the cubby box one. Travelling around in circles again. |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3980 ![]() ![]() ![]() |
It's a lot easier to do what Discotigger suggests than running a new cable.
Exactly nicedayforit |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7976 ![]() ![]() ![]() |
My cubby box one is always live. Must have changed on the later cars......
^ The wiring diagrams show two options, ignition controlled and not.
The easy way to find out is to look at the relay panel in the rear right hand cubby box. If there is a relay missing from the board and a metal bridge strap in its place, then the 12v accessory sockets will be permanently live. |
I think the 100mm of cable as suggested by nicedayforit is the way to go. Ta Travelling around in circles again. |
Just a point about the cable, as the circuit is fused at 20A the cable also needs to be rated at 20A. |
SKOT Member Since: 24 Oct 2012 Location: Milton Keynes Posts: 792 ![]() ![]() ![]() |
My 03 TD6 was always live, this 06 SC is not. It seems that it changed when it went from BMW to Ford under the skin.... 2006 4.2 SC
Scottyav Member Since: 11 Feb 2013 Location: Cannock Staffordshire Posts: 1204 ![]() ![]() ![]() |
Any pics of the relay you need to bypass? _____________________________________________________
