Home > Maintenance & Mods (L322) > judder when steering on full lock |
It could have something to do with the power steering pump drawing too much power in full lock.
17th Feb 2015 7:56am |
sasdiscos Member Since: 16 Oct 2014 Location: Northants Posts: 286 |
Could it be something as simple as a worn belt? You remind me of a young me, not much younger mind, perhaps even a little older! |
17th Feb 2015 8:38am |
Chasazim Member Since: 21 Jan 2015 Location: Perth Posts: 128 |
It could be a slipping belt, but i would have thought a squeel would allert you to that, it doesn,t do it all the time but when it does happen it is not a nice feeling, it feelslike the engine has hickups, thats the best i can explain it. I have ordered a set of sparkplugs, ii will change them and see if that helps, by the way i can,t even see the belts without pulling bits off.
18th Feb 2015 8:42am |
Well i changed the plugs today, bit of a concern, 3,4and 5 had a lot of oil in the plughole and when i removed the plugs they werelso oily, could have been from when i removed them though, on the other side 5, 6, 7 and 8 were fine, the plugs whitish which showed thhey were firing, but those oily ones, its hard to tell, i couldn,t see where the oil would come from, any ideas? |
24th Feb 2015 11:57am |
On most cars oil there is caused by leakage of the cam covers. MY 2010 5.0 SC Galway green and sand interior!!
24th Feb 2015 1:02pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7908 |
Can't think they would have been oily in the car, it will be the leaking cam cover gaskets causing it, if the engine light came on then it will have stored a code, get it read and go from there....
24th Feb 2015 8:22pm |
