Home > Technical (L322) > First gear whirring / whining noise |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7908 |
Never read about one whining, hopefully Phil will read this as he's the man who will know...
21st Feb 2015 12:05pm |
Blubberman Member Since: 11 Nov 2010 Location: South Wales Posts: 39 |
Cheers Pete, thank you for the suggestion
21st Feb 2015 6:03pm |
Strange it only happens in first, from what I can recall I don't think there would be many bearings specific to first, and as such you would think it would happen in more than one gear.
21st Feb 2015 6:12pm |
Yes it is a strange one, and to be honest most of the problems I have had with the Rangie over my 5 years of ownership I can find the answer to the problem by doing a search on FFRR or by googling other forums , ( that is why I don't post on here very often ) , but despite searching various forums and doing google searches I can find nobody else who has had this problem before.
21st Feb 2015 8:47pm |
You can't measure it anywhere near correctly with a gauge, the oil temp sensor is deep in the gearbox and the difference between the sump and the sensor will be massive, it is designed to be filled at a temp the sensor measures, you need an IID tool or something similar to measure it.
21st Feb 2015 9:22pm |
An update on the problem .
3rd Mar 2015 6:40am |
Craig (Cam Tech Craig) recently posted a warning on diff oil changes being needed regularly based on some issues he noticed with client cars, it sounds like yours also urgently needs the diff oils to be changed ! MY 2010 5.0 SC Galway green and sand interior!!
3rd Mar 2015 6:43am |
I did the rear one last year, but to be honest there was not much point because the oil that came out was spotless. I bought the oil to do the front one at the same time but never got round to it . Going to do the front one this week . Its big , its black and we call it THE BEAST ! |
3rd Mar 2015 6:54am |
Mate, I know what you mean and it happens to me a lot as well. Get the parts and then all kinds of other things happen in getting the work done MY 2010 5.0 SC Galway green and sand interior!!
3rd Mar 2015 6:58am |
