Home > Technical (L322) > coolant |
Garyfax Member Since: 02 Feb 2015 Location: Halifax Posts: 118 |
silly question maybe but best to check.
7th Mar 2015 9:59am |
Thanks. I bought some antifreeze and topped it up today, it only took about 1/4 pint so maybe its the sensor. I will keep an eye on it. thanks for your help. |
7th Mar 2015 7:48pm |
billcyn Member Since: 20 Oct 2013 Location: Whitby Posts: 56 |
Just replaced my coolant header tank c/w sensor after being driven nuts with "check coolant level" bongs.
7th Mar 2015 9:18pm |
Ziggy Member Since: 26 Dec 2011 Location: West midlands UK /sydney AU Posts: 265 |
I might be wrong but I am sure (I think) that sounds a bit daft......never mind back to what i think I may be sure about
7th Mar 2015 11:43pm |
As northernmonkeyjones said, you need a 50:50 mix of PINK antifreeze & water. This can be checked
7th Mar 2015 11:56pm |
Yes they do Ziggy |
8th Mar 2015 12:28am |
Yes they do Ziggy Thumbs Up
8th Mar 2015 9:39am |
Robert Member Since: 25 Oct 2011 Location: Perigueux Posts: 2281 |
Why is the color so important? Is blue not good for the RR? |
8th Mar 2015 8:51pm |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3194 |
As I understand it, pink is longlife - 5 years whereas blue is only 2 years. If you mix them it reduces the pink to 2 years.
8th Mar 2015 8:54pm |
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 |
Pink coolant every four years regardless of mileage. According to wiki. |
8th Mar 2015 9:21pm |
Depends on the engine chaps.
8th Mar 2015 10:15pm |
Yeh don't mix. But my td6 definitely pink. |
8th Mar 2015 10:25pm |
Strange that cos both my Bmw 3.0 diesels were blue?
8th Mar 2015 10:32pm |
Hmmmm does state in wiki longlife coolent. I always assumed that was the pink oat stuff every five years and blue every two years. But mines definitely pink. |
8th Mar 2015 10:45pm |
