Home > Technical (L322) > AC auxiliary fan not spinning ANY IDEAS? |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7908 |
Sound maybe the bearing on the compressor, you only hear it when the clutch cuts in and out about the right timings you mention... Mines been noisy for over 15,000 miles, keep meaning to sort it......
14th Mar 2015 7:47pm |
Starberg Member Since: 08 Jan 2015 Location: Karlskrona Posts: 70 |
Thanks for the help!
15th Mar 2015 3:47pm |
Pretty sure I read somewhere you can change the front bearing without removing the pump, although I haven't had a look at mine yet, if the pump still works then someone somewhere will be able to change the bearing...
15th Mar 2015 4:38pm |
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 |
Searched everywhere and it doesn't appear that the bearing / clutch Is available separately.
15th Mar 2015 8:06pm |
It'll be a standard bearing, just need to get it out and it and measure it....
15th Mar 2015 8:48pm |
Ahhh the old look up the bearing number.
15th Mar 2015 9:07pm |
Yes thanks Greg, new hip is great, on list for other one now, main problem is knee, now totally gone, won't lock straight, can't bend it past 30degrees... so it totally prevents me from getting my teeth stuck into the bigger Jobs on the FF... so just playing at the moment... got lots of big lumps of steel in the garage awaiting playing!!!! They can't do the knee until after the hip so a few more months to wait... Pete
15th Mar 2015 10:13pm |
Bl y hell mate your going through the mill, but glad things are going on ok. Ain't funny when you can't get out and about and under the rr. Good luck mate hope you get sorted |
15th Mar 2015 10:34pm |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2024 |
"Steve Austin, astronaut. A man barely alive." "Gentlemen, we can rebuild him. We have the technology. We have the capability to make the world's first bionic man. Steve Austin will be that man. Better than he was before. Better...stronger...faster."
15th Mar 2015 11:27pm |
Just back to some sort of normality would do..... Pete
16th Mar 2015 12:04am |
