![]() | Home > Technical (L322) > Parking assist module water ingress |
RJH Member Since: 22 Mar 2015 Location: Coventy Posts: 398 ![]() ![]() ![]() |
Hi guys,
Thats odd nearly always a sensor or the loom that needs replacing. If fault shown is more than one sensor faulty then its usually the loom. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35874 ![]() ![]() |
i'd find out where this module is and inspect around that area for any other damage and try and find out where this water is coming in ... ... - .- -.
They said there was no sign of water around it but when they took module out it was full of water & they suggested that there may have been a water leak previously that's been repaired, they checked with previous dealer that all history is with & they've not done any work on leaks.
a 2012my shouldnt leak and i concur with your suggestion that over zealous pressure washing could have caused it if, some other bits in tgat area were wet.. ... - .- -.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8822 ![]() ![]() ![]() |
That's very strange, it's attached to the back of the fuse box in the boot, if it had water inside from a leak then there would be a lot more around the fuse box... Early cars can rust out through the bottom of the rear wing but yours should be OK....
Thanks for the suggestions guys, I'll check it out once I've got it home & feed back.
Traditionally LR only sell rain capes for the nearside.....this is a new one on me! Land Rover Addict
I'm going on my 03 one and yes I had to remove the fuse box to get to it, just a few screws... didn't have to unplug anything to turn it enough to see the unit... yours might have far more stuff in there so take a few pics before you have a go at it..... Pete
Found my module easy enough, it's in left rear quater behind the removable panel & directly accessible. Had a good root arround today & found no signs of water leaking in to rear quater or sitting there, only evidence was 2 bolt heads directly below the module. Floor was bone dry & it's rained all day been for a run about & still none.
Yep, looks like you've found the problem... and does look like condensation... maybe a bag of silica gel in the new one?? Pete
Many thanks to Dan @Duckworth for supplying a replacement genuine module, speedy delivery & far cheaper than the dealers |
