Home > Maintenance & Mods (L322) > new to RR II ... a few queries though ...
Videoman1959
United Kingdom 2002 Range Rover HSE Td6 Zermatt Silver
Hi Everybody!
As the title says, I could do with a few questions being answered by the knowledgeable Gurus on this site, please.
My first problem is that a few bits of trim need upgrading/replacing as the vehicle is a L322, HSE, 2002 model.
I believe that my trim is 'cherry' wood. It is only light in colour and I dont think that its walnut, can someone let me know the difference please?
I could do with a sat nav too as this model doesn't have one. which one do you recommend please?
The front and rear parking sensors dont appear to work, but I believe that you a actually switch them on and off. Any advice on this issue would be great too. If I do press the 'P' button the light indicator flashes rather than stays lit, is this correct? I presume is suggests a fault, but where do I start looking ?
PowerfulUK appear to have most of the trims and parts for Range Rovers, are there any other 'players' in this market?
And also.... and I know that this problem is general with HSE's, what does one do about the door armrest 'crumpling' problem??
Thanking you for your help in anticipation. Smile
'Knowledge is Power'
Post #322245 12th Apr 2015 8:05am
please fill in your car profile so we know what you have.....most answers can be found in our wiki and by using the search function.... ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
workshop manual downloads are in our wiki
Post #322247 12th Apr 2015 8:07am
mjdronfield
Welcome.
To aid your searching a bit, if you want a sat nav that's built into the car you are best fitting an android unit, they are aftermarket and have the nav, music, media player etc. Haylands,a member on here, has done an excellent thread about fitting it to a Vogue with the amps and bits in the boot. Yours should be much easier as there is nothing in the boot to connect to, it's all in the dash.
The light should stay lit when the P is pressed.
Cherry wood is orange, walnut is dark brown, if that helps.
You will need to get the faults read by a garage or invest in an iidtool. Plenty on here about the iidtool. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #322254 12th Apr 2015 10:35am
Videoman1959
Not only but also...
Thank you for those answers, I will do as you have advised.
It is a light wood, so cherry it is then Smile
..and I will fill in the profile bit too.
ALSO ..
The front drivers and passenger seats have rubbishy, plastic surround with a silvery/foil plasticy bit on top of that... what is to be done with that to refurb etc... if anything??!
Cheers again.
And thanks to the person who moved my original post into this section.
Post #322298 12th Apr 2015 2:05pm
Mr Tee
Seat trims can be bought from Dan , one of the site sponsors, just look down the main index page to get his details.
Post #322299 12th Apr 2015 2:08pm
What Cherry trim parts do you need sir? What interior colour is your car as we may have a door card in stock sir... Thumbs Up
Post #322300 12th Apr 2015 2:08pm
Videoman1959
I have looked down the list of sponsors... unfortunately, non say 'Dan' ! lol Which firm is Dan associated with please? I see that the seat valances are 120 quid off fleabay. Sad
Thanks for that info! 'Knowledge Is Power'
Post #322305 12th Apr 2015 2:29pm
http://www.fullfatrr.com/forum/privmsg.php?mode=post&u=1284
Post #322308 12th Apr 2015 2:32pm
Videoman1959
It looks as though I may wish to change the foundry finish by the gear stick and perhaps the aircon/console area too. The rear panel for the heated rear seat switches and ciggy lighter is prob another replace. And without doubt, the door handle ( internal) caps, which are currently foundry will want replacing too.
Thank you 'Knowledge Is Power'
Post #322309 12th Apr 2015 2:32pm
Videoman1959
Post #322310 12th Apr 2015 2:33pm
Send me a PM and i will have a look tomorrow morning for you sir... I believe we have them all in stock as removed from a customers car due to piano black upgrade... Thumbs Up
Post #322311 12th Apr 2015 2:35pm
Videoman1959
will do , thanks. Smile 'Knowledge Is Power'
Post #322312 12th Apr 2015 2:37pm
Videoman1959
PM
Hiya Craig, I 'THINK' that I have sent you a PM. Neutral
Could you confirm please?
Cheers 'Knowledge Is Power'
Post #322802 16th Apr 2015 5:27am
