Home > Maintenance & Mods (L322) > Lumpy at 1600-1800rpms TDV8 -Sorted |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1692 |
Actuator live values and MAP live values |
12th Apr 2015 4:42pm |
stenh02 Member Since: 30 Jan 2011 Location: Somewhere not warm Posts: 340 |
12th Apr 2015 4:53pm |
Mike, thanks, one is at 2500rpm other at idle so about 740rpm.
12th Apr 2015 4:54pm |
Both boost actuators have shut down. With the live data displayed, switch the engine off, and restart after a few seconds. The actuators should move through their range of travel.
12th Apr 2015 5:14pm |
(Image deleted)
12th Apr 2015 5:33pm |
Both actuators appear to be working that time. I have a TDV8 with me just now, ill graph it in a bit
12th Apr 2015 5:36pm |
Thanks Mikey. Will keep an eye on the injectors. |
12th Apr 2015 5:45pm |
12th Apr 2015 6:26pm |
Looks like mine (apart from mine cycle open and closed about 5 times after I switch the ignition off) Mike, thanks for running that.
12th Apr 2015 6:30pm |
sako243 Member Since: 26 Dec 2013 Location: Wales Posts: 605 |
Mine sometimes had similar symptoms but I would describe it more as it was trying to hunt for gears, would bounce up and down between 16-1800 lethargically, and sometimes cough if you put your foot down. Gearbox oil change seems to have sorted that out nicely.
12th Apr 2015 9:45pm |
Will check that as well.
13th Apr 2015 8:55am |
After being fine yesterday and this morning. After work got the engine management faul in info centre.
14th Apr 2015 6:34pm |
I believe the one at 11% is stuck.
14th Apr 2015 7:12pm |
http://www.fullfatrr.com/gallery/albums/us...32E21.tiff
14th Apr 2015 7:26pm |
