Home > Maintenance & Mods (L322) > diff front draing and refil plug
viper
United Kingdom 2007 Range Rover Vogue TDV8 Zermatt Silver
Is that sucker 14mm/ 15mm hex ? not got anything that big
back diff appears to be 3/8 drive socket to drain and 8mm hex to fill
transfer box looks like a 8mm hex for both.
cant measure the front .
been under there tonight to penetrate oil it up ahead of the change at weekend
Post #322607 14th Apr 2015 7:12pm
markcaughey
Scotland 2006 Range Rover Vogue 4.4 V8 Buckingham Blue
14mm for the front drain plug if I remember right. Range Rover Vogue 2006 4.4 AJV8 | Buckingham Blue | Parchment Leather | Supercharged Grill+Side Vents | CA02 HEY ( NOT 02 PLATE )
Post #322611 14th Apr 2015 7:21pm
Always check you can get the refill plug undone first Thumbs Up .
Post #322628 14th Apr 2015 8:24pm
viper
thanks guys ,
if I cant get the refil undone I plan to turn the car upside down Rolling with laughter
Post #322630 14th Apr 2015 8:36pm
viper
another question , how do I know if ive an electronic or open rear diff, is it obvious with a wire or plug going to it
Post #322634 14th Apr 2015 8:41pm
markcaughey
Yep pretty clear when you get underneath, big plug on top of the diff well I think as mines didn't have one and was open diff. But when ordering the oil if you get it from Dan give him your chassis number and he can double check everything for you diff type, oil type and quantities just to be 100% Thumbs Up Range Rover Vogue 2006 4.4 AJV8 | Buckingham Blue | Parchment Leather | Supercharged Grill+Side Vents | CA02 HEY ( NOT 02 PLATE )
Post #322638 14th Apr 2015 9:07pm
