Home > Maintenance & Mods (L322) > Gearbox/Transmission in AJV8 |
markcaughey Member Since: 03 Nov 2014 Location: Glasgow Posts: 316 |
is the cattle grid you are experiencing at low revs when accelerating ? is making a noise or just juddering ?
22nd Apr 2015 6:57pm |
rej Member Since: 06 Jan 2014 Location: Stevenage Posts: 496 |
It is a physical vibration normally only under load, ie if I pull away gently it is ok. Car had lots of history to evidence servicing and various repairs with plenty of money being spent but I couldn't find anything gearbox related. However, the garage said the level was good and the oil looked clean and a good colour. I had told them to change if felt necessary at the time but didn't want to do for the sake of and possibly cause more problems.
22nd Apr 2015 7:24pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7908 |
I'm wondering how they know what colour the oil is if they didn't drain it out?????
22nd Apr 2015 8:23pm |
Pete, oil amount equal to the volume of shudder stop added was drained off so that the shudder stop would fit in the used to top off to correct level.
22nd Apr 2015 9:25pm |
Anyone recommend a gearbox specialist to take a look and change the oil
22nd Apr 2015 10:02pm |
I've found most so called specialists just say.... needs a new box... mainly because they don't want to guess wrong...
22nd Apr 2015 10:54pm |
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1898 |
^ second what Pete says, I had a judder at low speed and a booming sound at 50mph ish, I changed the filter and used correct grade atf as in the wiki by saintv8 ( great thread too ) and all seems good with the box, even going to say better as the changers are smoother, no judder at all, no booming sound that I can here.
22nd Apr 2015 11:12pm |
wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020 |
Its really easy to change the filter and oil. Mine came out very clean and didn't smell of anything metallic or burnt,,,
23rd Apr 2015 8:12am |
