Home > Technical (L322) > Vision Assist Pack |
ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1619 |
Hi there are a couple of threads on retro fitting venture cam - it can be done but no small job. as for the rest of the vision assist pack you are looking at new wing mirror surrounds and front cams. Plus there is also the tow assist function of the VA pack - I suspect some electrical jiggery poker required then plus of course all the CCF configs etc.
23rd Apr 2015 4:21pm |
IanT599 Member Since: 15 Jun 2013 Location: Wellington Posts: 351 |
We tow a caravan, a trailer and I'm sure the Mrs is after a horse box. Forgot about the blind spot probably also needs sensors to work properly.
23rd Apr 2015 4:40pm |
Agree - retrofitting all that lot would be lost cause on me too. 405 AB exec seats Baltic and Cirrus
23rd Apr 2015 9:53pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16171 |
4.4's are rare with VA package... The later the car the less they stuck on um as standard! |
23rd Apr 2015 11:06pm |
There is a cheapish hack that one of our Aussie forum members utilizes. Buy a cheap suction mount, stick a cheap older smartphone in it and us it as a Venture Cam to stream to your "normal" smartphone . MY 2010 5.0 SC Galway green and sand interior!!
24th Apr 2015 5:45am |
Found it http://www.fullfatrr.com/forum/topic24355....ne+suction MY 2010 5.0 SC Galway green and sand interior!!
24th Apr 2015 5:46am |
heppsen Member Since: 14 Feb 2012 Location: germany Posts: 170 |
Hi, my newly wquired 2012 TDV8 has this Vision Assist with Trailer aid system. Works a treat and its good fun using those cameras around the vehicle. I have not actively searched for it (nor for the whole vehicle) but it was a nice add on. The HD Logic 7 with 1200 Watts was more welcome... despite slightly dissapointing me on the bass/subwoofer quality. Back to camera system: you can actually save profiles for a couple of trailers and the system helps you find the correct trailer type. I do not have the venture cam though. But as I only very randomly tow a RIB I can live with this missing bit as I am able to look along the RIB on both sides with th erear view mirrors. regards heppsen 2017 MB V-Class 2016 Q7 (gone) 2012 FFRR TDV8 2012 Smart Pulse Turbo 1986 MB W126 1965 LR Series 2A 1961 LR Series 2 |
24th Apr 2015 7:02am |
Assuming the car has the VA pack from build. Would it have the charging point for the venture camera built in? |
24th Apr 2015 8:36am |
Correct me if I'm wrong, but was the Venture cam actually available on 2010 onwards? I'm not sure it was TBH. I thought is was only up to 2009MY.
24th Apr 2015 8:56am |
You're quite right Vision assist was never offered with a Venture cam but in the CCF of 2010> cars the companion camera file can be found leading people to think all you need is a charger and loome as well as a venture came to activate it in the CCF but I have no idea if anyone has succeeded. 2008 MY Supercharged
24th Apr 2015 9:10am |
IanV8 Member Since: 14 Jan 2010 Location: Dunfermline Posts: 502 |
I have got VA on my 2010, 2011my.
24th Apr 2015 9:25am |
Nice looking 2010 AB with vision assist on here if you don't mind white.
24th Apr 2015 9:39am |
Venture Cam is on lots of 09/10my cars in VSE & AB guise... I think you will find it was removed as standard fit on the 11my> much like RSE i guess... |
24th Apr 2015 9:44am |
Mrs doesn't fancy a white one. It is nice looking though.
24th Apr 2015 10:21am |
