Home > In Car Electronics (L322) > Mysterious Alarm trigger |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16176 |
Adam, a little known fact for you... If you open your bonnet then pull the bonnet switch UP “you will hear a small click” and it thinks its closed!
4th May 2015 11:10am |
CSK Member Since: 15 Oct 2010 Location: St Tropez Posts: 750 |
I had the same happening to me in my previous L322. Very common fault. I put a piece of self adhesive plastic under the bonnet right above the switch and that sorted it. I had previously put a new switch in but that didn't solve it. This piece of plastic did. Try it. |
4th May 2015 8:35pm |
Just found a bonnet switch for L322 in one of my draws if anyone's interested I'll happily post it if you PM me your address.
9th May 2015 8:02am |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 |
it does seem like the BMW bits on these are the least reliable parts! |
9th May 2015 8:31am |
