Home > In Car Electronics (L322) > ermm do i have bluetooth or not? |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16175 |
Yes you do sir... Put the radio on, search for bluetooth on your phone then find LR BT... The pairing code is 2121 |
17th May 2015 11:51am |
tommo Member Since: 17 May 2015 Location: kingsbury Posts: 9 |
Ahha awsome! Thanks for the quick reply! I have just tried but my phone (samsung galaxy s4) wont pick it up? I have uploaded another pic of the cradle or where the cradle should be do you think it is because i need this connected or a fuse has gone or something? Because from what i read i should press a pairing button where the cradle is? Thanks again for the help |
17th May 2015 12:16pm |
The cradle has nothing to do with the Bluetooth.
17th May 2015 12:21pm |
Mm i possibly have somthing wrong then i have tried that but will not find it with my phone or 3 other different phones. So eaither a faulty unit or a fuse i guess? |
17th May 2015 12:40pm |
PaulB Member Since: 17 Jul 2011 Location: Hampton Posts: 877 |
05 is the change over year where some things work and others need activating.
17th May 2015 1:18pm |
Or the BT module is damaged by water (happened to mine). Have a look in the rear where the BT unit is sitting on top of all the electronics (Left Hand side) in the rear electronics compartment. There should be some BT module pictures on the forum. Wiggs is your man to replace it with the latest software version by the way. This is his website if I'm correct : http://www.bluetoothexchange.co.uk/
17th May 2015 1:25pm |
marky777 Member Since: 05 Mar 2015 Location: Christchurch Posts: 141 |
Was not sure if mine had the bluetooth function, also 05 AB but just went outside and followed the steps above. Had to try twice but came up on my phone as Land Rover, paired and then entered the password and boom all working. Hope you manage to get yours going fella |
17th May 2015 1:39pm |
Ive just had another look at your picture and YES you have a problem sir The black EMPTY plug (next to the elec plug pictured) should have the fibre optic lead plugged into it! I guess its been bypassed as the BT module is dead! If you look at the bottom of your picture it looks like the white fibre optic lead is taped up! BEWARE... If you disturb that white lead breaking the loop/ring then your front screen will almost certainly stop working sir!!! Usual reason for the bodge thats occurred on your car is water leaking into the rear of your car so, first thing is to make sure its not leaking, then take the lid off the BT module and see if it resembles a pond! Then you have a choice to make! Replacements are around £300 from MD's |
17th May 2015 2:57pm |
Well yas were bang on! I took the unit apart and as you can see (another attached pic) water has obviously been in there at some point although there is no leak visable at the moment so i guess people before had the leak done and bypassed the unit. So its a new unit or a nice local electric place! Only thing i dont get the fibre optic wires (the two white ones) link from each unit and back to the loom as if there was never a plug for the bt unit? So how and where from was it connected to the fibre wires? |
17th May 2015 5:55pm |
do a search on here as there are lots of threads on this and a how too, for bypassing a fibre optic plug for testing purposes |
17th May 2015 5:59pm |
Cherrs but it is deffo the unit as you can see from the pic and the fact the system is working fine without the unit plugged it but im just wondering how do i connect it into the fibre optic wires if i get a new one as there is no plug for it? Or would i have to buy a plug from somewhere and put a plug back into the cables? |
17th May 2015 8:15pm |
Sounds like they have cut the plugs off the cables and joined them to maintain continuity.
17th May 2015 9:04pm |
Yeh looks like that to be honest i think the have and just disgarded one of the wires and a plug. I think i have found the plug believe it or not! I presume the wires just clip in i just have to find the cable now... mm tricky this is all providing the circuit board guy can repair the unit of cause! |
17th May 2015 9:33pm |
To let yas all know the board has been repaired (it no longer looks like it has been in a small fire!) All for a drink!! So next step is to find the fibre optic stuff to add a lead and plug back in the system i have messaged some guys on the internet breaking rangies for the fibre optic loom but to no avail so its a searching game and i can test it properly and make sure it works then have it updated if needs be by the company posted earlier.
20th May 2015 10:59pm |
