Home > General > Any ICE bofs on here |
speedymarktd6 Member Since: 20 Nov 2008 Location: Worcestershire Posts: 727 |
as long as you can get a signal from the head unit run it into an amp then into a sub enclosure it should be no probs for a stereo shop go to a good un tho and ask to see there work before hand hope this helps onto no6 Range Rover
19th Dec 2008 10:03pm |
kin Member Since: 20 Nov 2008 Location: rainy city Posts: 348 |
Thanks, would you know where the amp is installed in the RR? The amp may have a sub-output... |
20th Dec 2008 8:29am |
adara Member Since: 09 Dec 2008 Location: Eastern Europe Posts: 737 |
The sub is in the back, left side. The amp is also there. If you remove the left cover you can see both. I also find the sound dissapoiting, I had the Disco with the premium (non Logic7) before and it sounded MUCH better from less speakers... |
20th Dec 2008 1:10pm |
thanks, I've located the sub this morning, in the rear 1/4panel right next to the DVD nav module, a nice big black box with a 6" or 8" woofer, turned the volume up, you could feel it was vibrating, but somehow not much sound or very little sound coming out of it, I sat in the back seat, could feel or hear very little, the majority of the bass still coming from the front!! Too much power going into the midrange spks, and not enough power going thru to the subbox. I think a solution would be to install a decent, but discreet active sub-box in the boot, and reduce the bass setting on the HK itself, it should hopefully gives me the depth of bass I really wanted ps just in case anyone thinks I'm a chav blasting out music..I'm not!!! All i wanted was quality sound |
20th Dec 2008 2:36pm |
So true about the bass... I'm curious, beside the bass/treble and balance controls, aren't there other settings? Like, effect, delay, etc.? |
20th Dec 2008 2:41pm |
Nope! Just bass, subwoofer, and treble May be I'll ask JE engineering, a well known LandRover specialist whom also does ICE upgrade... |
20th Dec 2008 2:50pm |
Not many people seems to be interested in this, but heres the update anyway...
20th Dec 2008 6:04pm |
Neat! But couldn't you put it in the original sub's place? Here's what I found somewhere:
20th Dec 2008 6:39pm |
Hi Adara, that looks like a custom built box with may be a 10"woofer on it, the std HK sub enclosure only has a tiny 5-3/4" woofer!!! No wonder its making hardly any bass
20th Dec 2008 8:05pm |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6355 |
Never really thought the std Sub in the Sport or the Vogue does much, no matter what you set it too, can't really tell any difference.
21st Dec 2008 12:09am |
I can't even figure if the panel in front of the speaker is allowing soundwaves to pass through it... |
21st Dec 2008 8:58am |
It has a speaker grill on top of the panel to allow the sound out.... |
21st Dec 2008 3:26pm |
That small one? No way! That's why the lows are so puny... |
21st Dec 2008 9:34pm |
more update... had it installed this morning,more than happy with the result, the bass now has much more depth,and slightly softer,mine is a 12" active sub, although I suspect a good 10" will be just as good(will give more punchier sound), and saves more space.
26th Dec 2008 8:09pm |
