Home > In Car Electronics (L322) > Disconnecting battery |
I can't think of any reason why you couldn't disconnect the battery -ve terminal and re-connect on your return.
23rd May 2015 8:57pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34929 |
...and try your key in the door lock to make sure it works ok as you wont have the remote function. ... - .- -.
23rd May 2015 10:42pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16175 |
Not meaning to be a worry wart but, will your insurance company be happy with you doing that? Mine would have some questions if i had to claim... |
23rd May 2015 11:24pm |
How would they find out ? you can't steal a car with no battery and if the perps did reconnect it some how and get in the car the are unlikely to fess up aren't they 2008 MY Supercharged
24th May 2015 1:39am |
The alternative to disconnecting the battery is to leave it connected as normal and buy a smaller battery to sit in the boot which together with a set of jump leads would allow you to start the car should the worst happen.
24th May 2015 6:23am |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2026 |
I remember taking the kids to see some of the last Concord take offs at Heathrow, the thunderous roar from those engines with blue flame afterburners used to shake the fillings in my teeth, it was absolutely awesome! But laughed at the orchestra of car alarms all chirping from the (parallel to runway) car parks. There were three take offs a day I think. But I bet there is an on hand man with sack truck battery on leads, making a quick buck even today. |
24th May 2015 8:30am |
Because the OP stated he was going to on an open forum |
24th May 2015 9:02am |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7765 |
Spare battery or a booster pack has to be a better option - even just a set of jump leads - there will always be someone who will stop if you're standing in a car park with jump leads in your hand.
24th May 2015 9:23am |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 |
If you're leaving it at one of the decent airport car parking sites they'll be well used to flat batteries and be able to jump it for you should you need it. |
24th May 2015 9:28am |
